Viewing 15 posts - 4,171 through 4,185 (of 6,279 total)
  • in reply to: Installation of Webstation plugins #5518
    Or should I install the whole 5.7.0?
    This is better, because this is the future of Rapid SCADA.
    Read this topic for migration details.
    Can I install just the Scheme Editor 5.2.3.1 over Rapid Scada 5.6.1? How?
    Just replace the files of the editor.
    Scheme Editor app. does not open.
    This problem may not be caused by the app version.
    in reply to: Inactivation of Elastic report #5513
    The versions seem compatible.
    What is displayed for the plugin on the installed plugins web page?
    Please make a screenshot of the Interface table of the configuration database.
    in reply to: Installation of Webstation plugins #5512
    Note: There is a bug in saving files in Scheme Editor 5.2.3.0. You should take Scheme Editor 5.2.3.1 from Rapid SCADA 5.7.0.
    in reply to: Installation of Webstation plugins #5511
    You should also upgrade the plugins. Keys and settings are compatible.
    After upgrading, press Ctrl+F5 in your browser to refresh the scripts.
    in reply to: Log in web page #5503
    Use this link to open your web app:
    http://localhost/Scada/AutoLogin.aspx
    in reply to: Log in web page #5502
    Try this plugin.
    It logs in as the first user in the Users table.
    in reply to: Log in web page #5499
    Do you mean to log in automatically?
    in reply to: The event data #5498
    Currently no. If needed, you could purchase a development.
    in reply to: Change Colors #5493
    Event color also depends on input channel status like value color. The exception if a unit of an input channel has only 2 possible values, for example, Off-On. In this case, event are colored in red and green.
    in reply to: When communication loss #5492
    Also you can change Timeout on the Request sequence page in Communicator. It may make communication more stable.
    in reply to: The event data #5491
    You can download events in Excel format after selecting a day you need. And then check the events in Excel.
    in reply to: Voice Alarm & color Change #5486
    Voice Alarm is always alarm when the event change. if I need it to alarm when the status output change from 0 to 1 but when output = 1 change to 0 should not alarm.
    How can I do this.
    In this year we plan to issue a special notification plugin that solves this task.
    Please create a new topic for another question.
    in reply to: All value reset to 0 when device lost communication #5483
    in reply to: Retain Variable #5482
    When communication lost, you should get — in a screen. Why you get zero?
    How can we hold the old value until the communication come back.
    Try the formula: Cnl > 0 ? Cnl : Val()
    But this is a bad approach because an operator will be deceived in this situation.
    in reply to: Rapid SCADA Documentation PDF #5479
    Print Version
    Then press Ctrl + P and select “Save to PDF” in the Destination field.
