Change Colors
Forum Home › Forums › Understanding the Software › Change Colors
  • #5487
    scadarapid
    Hi.
    when I need to change the color of event on web page.
    Normally, we use formula to change the color on web page by choosing formula in Scada Administration and put some formula like this (Cnl;Cnl > 0? 25 :114) 25 and 114 are the color of event types in Administration but, if we already use some formula in that channel and we also want to change the colors of this event so, How can we do?
    example
    I use some formula in channel 1000 test(Val(1000),Val(1000)) and if I also need to change the color. How can we change the color.
    Thank you so much.
    #5493
    Event color also depends on input channel status like value color. The exception if a unit of an input channel has only 2 possible values, for example, Off-On. In this case, event are colored in red and green.
