MikhailModeratorIn the profile settings, set ScadaAdmin / 12345
You can also check /opt/scada/BaseDAT/user.dat Open it in a good text editor and try to find the above login and password. It must contain them.
MikhailModeratorI found that offline app somewhere in the internet and haven’t used it any more after developing the web parser.
MikhailModeratorhttp://modbus.rapidscada.net/
This one?
MikhailModeratorPlease describe your case in details. We can take it into account.
Thanks for noticing.
MikhailModeratorHow does the web interface of the camera work?
Try to create your own simple web page, which includes the video tag, according to this.
Does it work if you paste the URL into the browser address bar?
It depends on browser. You should try. Please share your experience here.
October 30, 2019 at 2:01 pm in reply to: Schedule function and screen editing alignment function #6025
MikhailModeratorWhat kind of actions or commands do you need to schedule via web interface?
> alignment
I agree. This would be very useful.
MikhailModeratorMe too. Sooner or later.
MikhailModeratorUser is optional. Probably, changing user somehow updated the output channel number.
The problem is that the destination folder is not empty.
1. Uninstall Rapid SCADA
2. If the folder C:\SCADA exists, delete it.
3. Install Rapid SCADA from the beginning.
Nice to hear)
MikhailModeratorThe module version is fresh.
The line in the log “Command is enqueued to be sent at 16:10:49. Device 0, Command 1” says that output channel number was not applied.
Try checking C:\SCADA\ScadaServer\Config\ModAutoControl.xml
Other way, in the trigger settings instead of output channel, specify the device number.
Also I can fix this remotely for a fee if needed.
