Viewing 15 posts - 1,051 through 1,065 (of 6,275 total)
  • in reply to: Communication status when no connection #14669
    To store last communication time, you need to create a new channel, and develop a formula that stores the time in that channel.
    Keeping last good value can be done by the formula.
    in reply to: TCP Server Connection Issue #14667
    In TCP communication, a connection brakes silently sometimes. If a client cannot poll a server, it must reconnect if there is no reply or connection is idle for a period.
    • This reply was modified 1 year, 12 months ago by Mikhail.
    in reply to: Historical data report achieve copy #14666
    May be change their archive kind to empty in the Archives table.
    Does it help?
    in reply to: Sum of Channels #14664
    In a formula you can check values of other channels. So you should add a function to the Scripts table, and then use that function in a channel formula.
    I will not write the formula for you, because writing complex formulas is a paid service, but I can help to solve the related questions.
    in reply to: Logging Data per second #14658
    Currently access by the above link is denied. Please make it public.
    in reply to: Logging Data per second #14651
    Dear Arya,
    I suggest to add a new archive in the Archives table and in the Server settings.
    This archive should not be default. Set archive mask for channels that will be written in the archive.
    in reply to: iframe is blocked #14650
    Since SCADA use port 80 and the embedded iframe use port 8080.
    Yes. It’s called origin. You should check the error details in the browser console and network tools.
    in reply to: HTTP driver #14647
    Also you can send a request according to the instructions and analyze it by Wireshark.
    in reply to: HTTP driver #14646
    Contact the provider’s technical support and ask for an example of content type and body of the POST request. Then use it in the device properties.
    in reply to: Linux #14645
    Check this topic.
    in reply to: html title when embedding webpage #14644
    If an external web page is open in a frame, we don’t have access to its title, because of browser security. Therefore URL is displayed.
    in reply to: HTTP driver #14638
    Try to configure DrvHttpNotif according to the provider requirements.
    CURLOPT_POSTFIELDS probably should be specified on the request body.
    in reply to: HTTP driver #14637
    Can the phone number of the recipient and the content of the message to be sent be changed?
    Yes. When command is send by Automatic Control module, the phone number is taken from the address book, and the text can contain variables.
    in reply to: Log records #14636
    Do you mean alarms and events or log files *.log?
    in reply to: HTTP driver #14630
    How the system should define what user should be selected as a recipient for an alarm?
