Sum of Channels
Forum Home › Forums › Understanding the Software › Formulas › Sum of Channels
  • #14660
    TroyV23
    I am monitoring many field devices which have an alarm bit. I want to create a calculated channel that shows the amount of alarms that are active (alarm==1).
    If there a way in formula to sum all alarms currently “ON”?
    There are about 50+ Alarms being monitored.
    #14664
    In a formula you can check values of other channels. So you should add a function to the Scripts table, and then use that function in a channel formula.
    I will not write the formula for you, because writing complex formulas is a paid service, but I can help to solve the related questions.
    • This reply was modified 2 years, 5 months ago by Mikhail.
