MikhailModeratorCurrent driver version supports number values. We will support 4 char strings in the next driver version.
You have to fill the tags in the device properties. One tag per line
MikhailModerator> I just want to know how many Y axes can be used at most
There is no software limit. If you create too many axes, they will appear ugly, I suppose.
MikhailModeratorCreate a channel of the Output type and set Tag Code to the above.
In version 6 you can send a command to restart a line.
Supported commands are here.
Command value is a line number to restart.
MikhailModeratorYes, this timeout also affects how long it waits for service command execution.
July 15, 2024 at 10:06 am in reply to: “Service control command failed” When uploading configuration #14936
It sometimes happens. Use IIS management console to restart the web application if it cannot be restarted programmatically.
I checked, 2001-01-01 is a starting point in demo mode, specified in the source code.
MikhailModeratorLikely, the service needs more time to stop. Try increasing the timeout in the profile settings.
MikhailModeratorPlease use a proper topic for another question that is not related to logging data per second.
There should be a solution in v6.
What is the math formula or algorithm?
MikhailModerator1. Set FileName=Astro2.csv
2. Locate the file in SCADA\ScadaComm\Storage
3. Set date to 2001-01-01 instead of 2024-07-09
MikhailModeratorIf DemoPeriod=OneHour, the 1st timestamp must be 2024-07-07 0:00:00 and the last 2024-07-07 0:59:00
MikhailModeratorOld manuals
https://rapidscada.net/doc/New manuals
https://rapidscada.net/docs/
The above link is wrong.
Please use this one https://rapidscada.net/docs/en/latest/modules/plg-dashboard -
