Viewing 3 posts - 6,271 through 6,273 (of 6,273 total)
  • in reply to: Scada Server connection problemes #61
    I think you should restore User table in the configuration database. Do the following:
    1. Open SCADA-Administrator and make a backup of the configuration database.
    2. Clear all the data from Users table.
    3. Unzip user.dat from ScadaAdmin.zip of the installation packege and overwrite the existing file.
    4. Import user.dat into the configuration database.
    5. Restart SCADA-Server.
    Open http://localhost/scada and try to connect as: admin
    Default password: 12345
    in reply to: Scada Server connection problemes #59
    Did this issue appear just after the installation of Rapid SCADA or after configuring?
    If you make some changes using SCADA-Administrator before the problem occurs please describe them.
    “http:\\127.0.0.1 in browser bar it shows me the IIS8 initial site” – it’s OK.
    • This reply was modified 11 years, 4 months ago by Mikhail.
    in reply to: Installation errors #56
    Dear Akbarm,
    Please post the following additional information about the issue:
    1. What were the errors occured during installation?
    2. What is the state of SCADA-Server when it runs? The state is written in C:\SCADA\ScadaServer\Log\ScadaServerSvc.txt
    This issue often appears if some other application uses TCP port 10000. For example, torrents client. In this case, close that application and restart SCADA-Server service.
