Viewing 15 posts - 6,076 through 6,090 (of 6,270 total)
  • in reply to: Communication #577
    EB 76 is the checksum
    43 D0 FE 05 is the value 417.984528
    You should set the correct bytes order in Device Template Editor.
    Try the order 2301.
    Please notify me about the result.
    in reply to: Communication #575
    I would like to see the log.
    in reply to: Communication #572
    Can you post here a part of communication line log? And the expected value.
    If it is possible also provide MODSCAN log for comparison.
    in reply to: Data input #569
    There are a few ways:
    1. Export data, then import the same data with other IDs in SCADA-Administrator.
    2. Generate SQL queries, connect to ScadaBase.sdf using a tool supports Microsoft SQL Server Compact 3.5 and execute the queries.
    3. For input and output channels there are the built in auto create and clone features.
    • This reply was modified 10 years, 8 months ago by Mikhail.
    in reply to: Data input #567
    Could you provide more details about your task? What kind of data do you need to input?
    in reply to: Automatic Control Module #565
    This function has not been developed. I mean that you could purchase the development.
    in reply to: Automatic Control Module #562
    Yes, you right. When you use Automatic Control Module, an output channel formula does not work, because the output channel is not specified in the trigger commands. To implement this function the development is required. If you really need this, you could purchase the upgrade.
    in reply to: Sending multiple commands #550
    Yes, it is possible with help of Automatic Control Module. You should create a command trigger and a set of commands bound to it.
    in reply to: Sending Int16 or Uint16 as command value #548
    Hi Dejan,
    Thanks for the response. The bug was fixed. You can download the installation package again and reinstall SCADA-Server.
    in reply to: Automatic Control Module #545
    You should download the components of the version 4.5. They have been published recently.
    in reply to: How to get the data which automatically sent by the devices? #544
    Special device driver is needed. Driver development is described here http://rapidscada.org/device-drivers-development/
    You could develop it by yourself or purchase it.
    in reply to: Modbus addressing size #541
    400001 means that you should select Holding Registers (4x) data table and the 1st start element address.
    in reply to: How to get the data which automatically sent by the devices? #539
    1. Could you provide an example, please?
    2. Probably you should implement or purchase development of the device driver if your device uses its own communication protocol.
    in reply to: Automatic Control Module #538
    What version of Rapid SCADA do you use?
    in reply to: Failed to Invoke: ShowDiag error #534
    No, it’s free. There is an extended commercial version.
