MikhailModeratorSolved. Will be published in the next version.
MikhailModeratorRadix, could you write the required formula using C++, C# or math? In this case, I can tell how to apply it to Rapid SCADA.
MikhailModeratorI you don’t find the answer with Chrome, I’ll help you, OK?
You can easily the find the answer with help of Chrome. Press F12 and find the element by a mouse. Chrome displays the css file and line number.
I recommend not to waste much time, because the web app will be totally redesigned.
MikhailModeratorFirst of all, let’s make sure about the reason. Please write about the result after changing localization.
The manual is inside the installation package. The file name is Doc\dbexport_en.pdf
Try using database model and scripts from the manual.
MikhailModeratorI think it will be good idea to implement connection timeout. It will be done in a one of the future version of Rapid SCADA. Also this work can be accelerated on commercial basis.
MikhailModeratorAs an option you can split polling into several communication lines to communicate in parallel.
How long does it wait if connection can’t be established?
MikhailModeratorLook for the cause in C:\SCADA\ScadaServer\Log\ScadaServerSvc.log
MikhailModeratorThe cause that Mono can’t compile the line 79
initialCmdVal = 0.0;
that is shown in ScadaServer/Log/CalcEngine.cs
MikhailModeratorDo you use comma as decimal separator?
I think the most simple way to switch location and language back to English and check whether error disappear or not.
MikhailModeratorSuch error appears on Germany localization because of Mono bug. What OS culture do you use?
Look at C:\SCADA\ScadaServer\Log
What are in log files?I strongly recommend to use RAM drives for log folders in case of using SD card.
MikhailModerator🙂
MikhailModeratorThanks for the info.
