MikhailModeratorThere are 3 ways:
1. Optimal. Export these data to DB using DB Export Module. Then use this approach to display charts.2. Fast to implement. Manually set storing period for minute data in C:\SCADA\ScadaServer\Config\ScadaServerSvcConfig.xml
Cons: large data archives and slow charting3. Create a custom solution to fit your needs.
MikhailModeratorThank you for the research. It would be useful to optimize the chart.
MikhailModeratorNothing is impossible 🙂
MikhailModeratorNo, I think it’s better to release the new web app ASAP.
Do you mean that you need to store data every second?
MikhailModeratorWithin a few months.
The spring was too optimistic. The work is in progress. You can see a screenshot here. I hope the result will satisfy our users.
MikhailModeratorWRITE EVENTS: if false, no event for the channel will be written and shown.
EVENT SOUND: plays beep in browser. Just try.
EVENT ON CHANGE: on any change. Usually the option is used for discrete values.
EVENT ON UNDEFINED: e.g. connection is lost. Event fires when the channel status is 0.
LIMIT: I recommend trying it using SCADA-Server generator.
Object field is optional. Device field is required if channel value is measured by a device.Are any events shown when in Report/List Chart view?
Sorry, I didn’t catch the meaning.
Have a nice weekend too 🙂
What is load profile?
MikhailModeratorBased on your ideas I can generate inherited ideas 🙂
MikhailModeratorThanks for the ideas!
To view all daily events, you should export them to Excel.
Checked events have the same behavior as others.users should not have access to that tool.
Users must not have access to the server file system.
How/where could I see/configure more than the last 9-10 events?
Use SCADA-Web Configurator -> Visible events count
How can I easily do an event sent an email ? Do I need to create a rule on Autocontrol for each channel
Yes, you should create a rule. If it’s enough to receive the same message, you can create some kind of aggregation channel. In case of using limits, you can specify trigger on status.
Where are they stored (in case you need to delete ie… 100’s) ?
See directory settings of SCADA-Server.
MikhailModeratorFixed. Thank you for the bug report.
MikhailModeratorYes. Download Rapid SCADA Mono. Manual is made for Debian.
But in the current version schemes are not accessible. The new web app is OK.
MikhailModeratorHmm in the place of the event window? Or alongside the event window?
Custom Data window. Events closes when another window is shown.
In any case a minimize button for the new window if there is one and a minimize button for the event window would be nice.
It exists – the gray circle with arrow.
the event window will automatic open again when a new event happens
Notifications like Skype would be nice, but not in beta version.
