Viewing 15 posts - 5,746 through 5,760 (of 6,275 total)
  • in reply to: Graphs: unlimited channels and multicolumn legend? #1379
    I wonder if you are already using SQL Server lite for objects/channels… why not for data too?
    Pros of file storage:
    – Performance
    – Works great on systems with low resources, e.g. Raspberry Pi
    – Easy to refactor depending on the project needs
    – No dependencies on 3rd party
    Cons:
    – Unable to write SQL requests
    – Unable to retrieve data using standard tools
    The ideal way is to implement the ability to use different data storage engines.
    in reply to: PLC data in flat files. #1377
    You need to develop or purchase a module for SCADA-Server. Use this one as an example.
    in reply to: Graphs: unlimited channels and multicolumn legend? #1376
    This limit is defined in DiagCnls.aspx. You can change it, I think it should work.
    You right, the possible problems are layout and performance.
    How many channels do you compare in the work proccess?
    in reply to: OPC Server in RapidSCADA #1373
    Please, create a new topic, this one is not appropriate. Furthermore, provide more details about your task.
    in reply to: How to modify many database fields content easily? #1370
    You should use srezAdapter.Update(srezTable) method after modify data in srezTable.
    Changing data:
    https://github.com/RapidScada/scada/blob/master/ScadaServer/ScadaServerCtrl/FrmSrezTableEdit.cs#L331
    Saving: https://github.com/RapidScada/scada/blob/master/ScadaServer/ScadaServerCtrl/FrmSrezTableEdit.cs#L103
    “Srez” means a snapshot ))
    in reply to: System Crash #1369
    For the old web app you should enter views into the Interface table if you need custom user roles. For the new web app all the views must be in the Interface table.
    in reply to: System Crash #1366
    Are you talking about the new web app or about the current version? My note was about the new.
    in reply to: System Crash #1364
    The server code of the all Rapid SCADA applications are highly stable, and the apps work for months and more without restarting.
    The issue may occur with a browser on a client side if the browser doesn’t be reopened for a few hours. The new web application which works great is under active development. You can install the prototype (see this link)
    in reply to: New Web App Idea? #1363
    For now the prototype supports schemes, table views and events.
    Charts, commands and reports are under construction.
    Use fresh version of Chrome (recommended), Firefox or Edge. It also works on iOS and Android. Don’t forget to update your browser.
    In case of issues, please, create new topics.
    in reply to: New Web App Idea? #1362
    I have published the prototype http://rapidscada.org/download/scada_web_beta.zip
    Look for installation instructions in manual_setup_en.pdf of the main distributive package.
    The files of the prototype have to be located in C:\SCADA\ScadaWebBeta\
    Define views using SCADA-Administrator as shown on the screenshot
    postimage
    Then enter view IDs in the file C:\SCADA\ScadaWebBeta\ViewSettings.xml
    in reply to: Using formulas bit confusing #1360
    Function and variable names are case sensitive. Check it.
    in reply to: System Crash #1358
    Try the same but close a web browser. The web application may cause browser memory leak, unfortunately. The new web app works well, it will be released soon. If needed, I can send you the prototype of the new web app.
    in reply to: modbusTCP #1355
    Definitely.
    If Communicator interacts with Server, communication settings of Communicator app are overridden by the configuration database.
    P.S. You can also use Russian forum if it’s more suitable.
    in reply to: How to modify many database fields content easily? #1349
    A simple application is needed to update data because the archive is not SQL database.
    in reply to: Error in TCP modbus simulation #1346
    Can you see input channel numbers in the Channel column of Device Data page in Communicator? If not, it means that input channels are not bound to the device tags, so data are not passed from Communicator to Server.
