Viewing 15 posts - 556 through 570 (of 6,270 total)
  • in reply to: Event marker not found #16314
    Use the DatViewer utility to check the event files. Event files are SCADA\Archive\Events\events*.dat
    May be an event file is corrupted.
    in reply to: Not getting to view as a web page #16311
    Can someone provide an example of what the deployment profile entries should look like?
    Please create a new forum topic to discuss this question.
    I thought entering the same thing on another computer in our network would display the same page, but it just times out.
    Allow incoming connections to the port 10008 in the Windows firewall settings.
    in reply to: How to use ModArcPostgreSql? #16310
    > what is the function of Pull to period
    For example, you set it to 10 seconds. If a timestamp of the point is 10:59:51, it will be changed to 11:00:00.
    > what is the function of Use in-memory cache
    Caching will be useful when data from multiple devices arrive at the same time stamp. This usually happens when a new hour begins. In this case, the channel values ​​for this time stamp, which are necessary for calculations using formulas, will be read from the DB only once. If the project has many thousands of channels with formulas, the difference in data processing speed will be significant.
    A driver should support reading archives from your devices.
    in reply to: Not getting to view as a web page #16306
    Let’s discuss another topic in the appropriate forum thread. Use the search, maybe the answer is already there.
    in reply to: Not getting to view as a web page #16303
    “An error occurred while processing your request.” is a sub message.
    If you see it, check the details in ScadaWeb.log
    When it happens?
    in reply to: Buid Rapid SCADA 6 on Visual Studio Code #16302
    There is no plans to adopt SchemeEditor for Wine, because I hope, the new MimicEditor will be released. But I don’t know when it happens. The work in progress.
    Can you run ScadaAdmin on arm64? If so, how to achieve that?
    in reply to: Auto Control Module Bug #16301
    Please provide screenshots of the module settings and log.
    What are the versions of the Server service and the module?
    in reply to: New release Rapid SCADA 6.4.x #16294
    Rapid SCADA 6.4.1 has been released.
    – Improved API of plugins and extensions (backward compatibility is supported)
    – Fixed errors in MQTT and DB Import drivers
    – The Server service writes initial command values ​​to events before calculating by formula
    – PostgreSQL historical archive supports in-memory caching
    The projects are fully compatible with the previous release.
    in reply to: Not getting to view as a web page #16292
    You can see that the Channel column is empty. It should be filled by the channel numbers. I suggest to delete the channels related to the device (in the Channels table) and create channels again using the wizard.
    • This reply was modified 1 year, 2 months ago by Mikhail.
    in reply to: Not getting to view as a web page #16290
    After you successfully displayed a table view, you should check a data page in Communicator to make sure that you receive valid data from devices.
    in reply to: Not getting to view as a web page #16285
    Please check ScadaWeb.log for the error details.
    in reply to: schemeeditor doesn’t launch at all – windows11 #16284
    Wow! Windows is unpredictable sometimes.
    in reply to: Tagging Asset using SCADA #16278
    Could you clarify the question?
    in reply to: Not getting to view as a web page #16277
    In ScadaServer.log, there is no connection made by the ScadaWeb user. It looks like the web application tries to connect to another TCP port. Open the connection options of the Webstation app using the Administrator app and check that the port 10000 is set there.
    in reply to: schemeeditor doesn’t launch at all – windows11 #16270
    Make sure that the latest updates are installed on your Windows 11.
