Viewing 15 posts - 5,386 through 5,400 (of 6,288 total)
  • in reply to: Problem in Sending Modbus (Command) Float32 data #2249
    Thank you for the details.
    You should understand how the data are encoded when you send the command 0x10 (Write Multiple Registers):
    You can choose either:
    1. Binary command. Using this option you can explicitly specify the bytes which are sent. Let’s try it.
    2. or Standard command. See these lines:
    modbusCmd.Data = cmd.CmdTypeID == BaseValues.CmdTypes.Standard ?
    BitConverter.GetBytes(cmd.CmdVal) : cmd.CmdData;
    The value 14 is 0x402C000000000000 when converted into a double (see this). Then you send the 4 bytes from the right that are zeros.
    You can create formulas in the configuration database to convert data entered by a human to the format described above.
    in reply to: The problem about ModDBExport module #2248
    Please provide the detailed description of the required changes.
    in reply to: Problem in Sending Modbus (Command) Float32 data #2242
    I validated the packages by http://modbus.rapidscada.net/ They are wrong. Communicator never sends wrong requests.
    If you need to send float, you need at least 4 bytes to store it. So you can’t use Write Single Register command which sends 2 bytes.
    in reply to: Reconnect OPC Server #2241
    Just right click the tree node and choose restart the line.
    in reply to: Reconnect OPC Server #2238
    Communicator can’t restart OPC server because this is another application. Is it enough to restart communication line to repair a connection?
    in reply to: Problem in Sending Modbus (Command) Float32 data #2236
    then I couldn’t save this change as kpModbus.dll
    Please explain what do mean? How do you do this?
    I think, it’s possible to solve your issue without changing KpModbus.dll. I can tell how to configure it if you provide more information: what value should be sent by an operator and what data (in hex format) should be sent to the device?
    Update: usually the command 0x10 (Write Multiple Registers) is used for sending float data to a device. In this case you can tick the Multiple command checkbox in Communicator and send any data.
    • This reply was modified 9 years ago by Mikhail.
    in reply to: Communication errors #2233
    Which development environment You use? It is .NET?
    I use Microsoft Visual Studio 2015 Community Edition.
    In case of questions about programming, create new posts in http://forum.rapidscada.org/?forum=development-and-integration
    Let me know when Bosch answers about Modbus TCP 🙂
    in reply to: Commands in Modbus #2232
    You can purchase a training and we will solve the issues together via remote connection. Please send an email to get information about the prices.
    in reply to: Alien LiveChart or Gage #2231
    Yes, you can do it using JavaScript:
    scada.clientAPI.getCurCnlDataExt(cnlFilter, function (success, cnlDataExtArr) {
            if (success) {
            // your code here
    Please ask more specific questions.
    If you’d like, we can create a simple application together as a part of training.
    in reply to: Communication errors #2227
    I’ve read. Definitely, there is no notes that Modbus is not standard. Strange, Bosch is well known brand.
    Before decide, you should try to read other kind of data – input registers and check if it works or not, and what the issues are.
    Also I strongly recommend trying Modbus RTU mode. It is strict and includes check sum. There is no way to dodge with protocol.
    in reply to: Sending PDF with Email #2226
    The chart drawn by the web application of Rapid SCADA can’t be used for automatic mail, because it’s generated by JavaScript in a user’s browser. The special module have to be developed that run on a server side. We can develop the module for you as a custom development or consult you how to do it by yourself.
    in reply to: Commands in Modbus #2221
    Example:
    Expected value of the tag #1 is 10, actual value is 0.
    in reply to: Links in the Scheme #2220
    Currently, it’s not implemented. Planned in the future version of schemes.
    in reply to: Communication errors #2216
    I mean:
    What is Enron Modbus?
    Enron Modbus is a modification to the standard Modicon modbus communication protocol developed by Enron Corporation.
    See http://www.simplymodbus.ca/FAQ.htm#enronmod
    in reply to: Communication errors #2215
    Hi Marek,
    Probably the device uses a derivative protocol based on Modbus, but not standard Modbus. And this is the cause of the problems. Please read carefully the device manual. What is written in the manual about the supported protocol?
