Viewing 15 posts - 466 through 480 (of 923 total)
  • in reply to: Rapidscada in Debian (on IoT2050) #12210
    curl -sSL https://dot.net/v1/dotnet-install.sh | sudo bash /dev/stdin –канал LTS –среда выполнения aspnetcore –install-dir /usr/share/dotnet/
    where LTS is with long-term support, you can use Current, such as the current version.
    –runtime aspnetcore — install runtime only ASP.NET Core
    Add a path as needed
    export PATH=”$PATH:/usr/share/dotnet”
    or a link
    sudo ln -s /usr/share/dotnet/dotnet /usr/bin/dotnet
    have you tried installing it directly through the script?
    in reply to: Rapidscada in Debian (on IoT2050) #12205
    Did you remember to make a symbolic link to dotnet ? It is in the installation instructions.installation
    1.4. Create a link to the dotnet file:
    If there is a link, you need to look at the logs, why dotnet was not installed
    Check the processor of your device, if it is ARMv6, then you will not be able to put dotnet on this device
    in reply to: Rapidscada in Debian (on IoT2050) #12175
    port 10008
    localhost:10008
    in reply to: ArchiveDATCopy #12041
    in reply to: Remote Communicator Error #12017
    Not required. You have a PC with a Communicator should be in a separate instance, in which the server address should be specified in the Communicator settings – the 1st PC
    in reply to: V6 Video Support #11845
    Yes, the Address was replaced with a Numbered Address, the Callsign was replaced with a String Address
    Many things are clear simply because they are not in the same positions as the 5th version.
    in reply to: What is the default Password in version 6 #11799
    scada
    So far, it can only be generated in Visual Studio like. Using the scada core code. Promised to add to the functionality in the near future
    • This reply was modified 3 years, 4 months ago by manjey73.
    in reply to: Send command #11718
    The command is sent immediately, there is a checkbox in the survey settings for polling immediately after the command
    in reply to: What is the default Admin Password in version 6 RC1 ? #11703
    7. After restart, open http://localhost or http://SERVER_IP in a web browser
    Username: admin
    Password: scada
    in reply to: Danfoss ECL 200/300 driver #11700
    Source Code
    Driver for RapidScada version 6
    in reply to: Channels Communication and Reset #11636
    It is impossible without the module in automatic mode without the participation of the operator. The module is designed for this
    On the second question, it is not entirely clear what is being reset?
    in reply to: Maximum number of Modbus devices #11530
    In version 6 of RapidScada there are no restrictions on the number of channels. You can also connect more devices than 65535
    in reply to: Error message xml not found #11463
    Copy this file to the project folder and then transfer the configuration to the server… In the beginning, it was necessary to download the WEB configuration immediately after installing the plugin
    in reply to: Omron Fins Driver (Ethernet) #11381
    Perhaps it will help you how it is implemented for another PLC in C code.
    https://github.com/libplctag/libplctag
    There is an export of functions in the source code and they are used differently in builds for Linux and Windows libraries. If it helps for understanding.
    in reply to: Omron Fins Driver (Ethernet) #11379
    The key there is this
    [DllImport(“libwiringPi.so”, EntryPoint = “wiringPiSetup”)]
    public static extern int Setup();
    and so on
