Viewing 15 posts - 406 through 420 (of 923 total)
  • in reply to: Button to open a table #13478
    You can, you need the Link component in it you can set the url of the link to the desired view
    in reply to: Dashboard Plug Issue Using xml File #13392
    @yotool I would like to know how do you monitor the ds18b20 ?
    Do you use a Modbus card for these sensors or do you read them using 1 Wire ?
    I’m still using scripts in crontab and in scada
    in reply to: Dashboard Plug Issue Using xml File #13378
    Does not show screenshots, as they are either not shared or unavailable
    in reply to: Channel with Self Increase / Decrease Value #13368
    All formulas in Scada channels are always executed in a loop. Imagine that you are programming a PLC in LAD language. That’s about how formulas are processed in Scada channels. The sequence of calculations of formulas from the smallest channel number to the highest. Therefore, if periodic calculation of formulas is required, or you need to use built-in tools Every minute, every hour, or create your own timers, triggers, and so on, according to which you already perform actions.
    in reply to: Installing Licensed Plugins in v.6.1 Beta #13366
    ../ChartPro/ChartPro.aspx?cnlNums=160,161,162&viewIDs=2,2,2&title=Title
    It seems that links should be made in a similar form. Here is an example of a link to a set of graphs of several channels.
    Something like that, probably.
    in reply to: Channel with Self Increase / Decrease Value #13358
    Yes, channels are processed several times in one second. Use the built-in formulas once per Second, if available. Or use timers with the necessary delay before adding or subtracting.
    in reply to: Installing Licensed Plugins in v.6.1 Beta #13349
    Web – Application Parameters – Plugin Assignments
    I don’t know exactly how it is in the English version, but I think you will find it. Replace the chart opening behavior there from the usual default to the ChartsPro
    in reply to: Installing Licensed Plugins in v.6.1 Beta #13346
    When working with a remote server, you need to install and configure a PC with an Administrator and on a remote server for the settings functionality to work correctly. In this case, it is necessary to register only on a remote server, where the plug-in, module or driver will work directly
    in reply to: Installing Licensed Plugins in v.6.1 Beta #13345
    Copy the plugin according to the folders. Run the Administrator, do download the configuration from the server. You will see all the configuration files in the WEB tree. Open the Plugins section in the WEB tree and connect the required one.
    in reply to: Dashboard Plugin #13344
    The plugin is configured for the amount that you need. The question about kits is not quite clear? It starts working in full on one web server without restrictions.
    in reply to: plugin install no activation in web #13274
    In version 6
    Download the configuration from the server – to get all the configuration files in the project.
    Go to the WEB settings in the Administrator, Plugins – enable (connect) the plugin
    in reply to: add new condition ins scada scheme V5 #13215
    It is better to do it through a plugin, for the possibility of transferring later to version 6. But given that version 5 is no longer being developed, you can do it directly, but it will only work in version 5. If you write directly in version 6, then after updates you will have to integrate the code again and again after each update.
    in reply to: Add new conditions #13201
    Now it is not very convenient, since it is necessary to develop for the Schema Editor in the 5th version, and at the same time make the plugin for the 6th version. It will be easier when the schema editor is ported to the 6th version.
    in reply to: Copy automatic control module configurations #13189
    you have to copy the configuration between the project folders
    in reply to: Convert decimal to hexadecimal from web browser #13155
    It seems there were publications on the Russian forum. As far as I understand, there is a difficulty only in transferring the database
