MikhailModeratorDatToCsv.exe for v5 creates csv like https://ibb.co/QfcMW7Q
MikhailModeratorUsing Administrator v5 we can export to this csv https://ibb.co/jhTFJmR
It would be useful to be able to import such file into v6.
If channel status is 0, a cell is empty. Otherwise, let’s assume status is 1.December 7, 2023 at 10:14 am in reply to: Communicator Send only modified data of device tags setting #13792
In pgAdmin right-click the Databases node and create a new database, named rapid_scada
MikhailModeratorCould you provide more details about your task?
MikhailModeratorIn Rapid SCADA 5 it should work.Probably, you right.
In Rapid SCADA 6 currently there is no option to hide bottom panel. Should we implement such option in version 6?-
This reply was modified 2 years, 4 months ago by
MikhailModeratorCould you describe the context of the task?
December 5, 2023 at 8:54 am in reply to: Communicator Send only modified data of device tags setting #13781
MikhailModeratorIn version 6 you can enable PostgreSQL archives.
This feature I didn’t try yet, will try and see soon.By default PostgreSQL parameters are
localhost
User: postgres
Password: postgres
Database rapid_scada should be created manually.December 5, 2023 at 8:52 am in reply to: Manually update rapidSCADA under Linux, how to prevent data files from being ove #13779
MikhailModeratorAlso each application has it’s own configuration. For example, ScadaServer/Config
And keep the Views folder.-
The log file says Communicator cannot connect to the SCADA-Server service.
Also check ScadaServer.log
In general, I suggest to use Rapid SCADA 6 instead of 5.
At this moment there is no data editor to change *.dat files manually. ScadaTestClient should be used for this purpose.
For bulk data update it would be more useful to develop an application that is not format dependent and can write data to any type of Rapid SCADA archive. Like importing CSV data to a specified archive.
December 4, 2023 at 11:20 am in reply to: Communicator Send only modified data of device tags setting #13773
December 4, 2023 at 11:19 am in reply to: Communicator Send only modified data of device tags setting #13772
By default Communicator sends data on change and sends all data every minute.
But on the screenshot you disabled sending all data because period = 0.December 4, 2023 at 11:17 am in reply to: Manually update rapidSCADA under Linux, how to prevent data files from being ove #13771
MikhailModeratorOption 1
Upload the project again from Windows to Linux after update.Option 2
Copy the application files manually to keep the configuration unchanged.
Please provide screenshot of the Interface table and a web page.
Rapid SCADA 6 is recommended over version 5.
To do that, you need to specify different configuration files for different OPC servers to use different TCP ports. -
