Viewing 15 posts - 1,126 through 1,140 (of 6,221 total)
  • in reply to: Convert historical data from V5 to V6 #14291
    It is important to find the cause of the error. May be those files contains correct and useful data. Could you open the problem files in the Administrator app to view data and try to realize why they can cause the error?
    in reply to: New release Rapid SCADA 6.2.x #14283
    Rapid SCADA 6.2.1 has been released.
    The release contains error fixes, as well as a new module Difference Calculator (ModDiffCalculator), which is useful for calculating consumption for a period.
    in reply to: jQuery issues in #14276
    RenderContext is created here.
    imageMap is initialized here.
    in reply to: Convert historical data from V5 to V6 #14275
    You should run cmd first. Then execute the *.exe in the command prompt.
    in reply to: Webserver issues on win 11 #14274
    What error do you get when open http://localhost:your_port ?
    Does the above help?
    in reply to: Webserver installation isssues #14272
    First of all, check that AspNetCoreModuleV2 is installed as shown here.
    in reply to: How to install Rapid SCADA on ubuntu server ? #14268
    Messages related to the competitive software will be deleted. To solve an issue, please ask certain questions providing logs and screenshots.
    in reply to: Current Data sudden become Not Ready #14257
    in reply to: API for Integration #14244
    The above message that does not correspond to the topic of the conversation has been deleted.
    in reply to: Current Data sudden become Not Ready #14242
    It can be a good idea. Please let us know if it helps to solve the issue.
    in reply to: little misunderstanding with the OPCUA Events #14236
    If you provide screenshots from any OPC UA client that does what you need, it can help.
    in reply to: User Input on Table View #14231
    Create a single channel of the Calculated/Output type. Set the Output formula to SetData() After making that settings it should be possible to change channel value by a user. This does not depend on the device.
    If you need to set Modbus register according to a command, configure the Modbus template, and then create channels by a wizard.
    > it is possible to create a Virtual Device
    Yes. In this case, a device just helps to group channels. Calculations are defined by channels.
    in reply to: Current Data sudden become Not Ready #14228
    It seems that we are close to understanding the cause.
    If you restart the PC in usual way, do you get the same error?
    in reply to: Custom Page #14227
    I’ve wrote down a note to increase the priority of this task.
    in reply to: Modbus Data Formula #14226
    > Is there a way for me to define what the event says?
    The answer depends if you use Rapid SCADA 5 or 6. For version 6, set channel properties:
    Input formula would be Cnl > 0 ? 0 : 1
    Format is Off-On
