MikhailModeratorIt’s big 🙂
> Should I 44,640 X 30 (channels)?
Yes.Try increasing ConnectionOptions – Timeout in ScadaWebConfig.xml. Are you able to get more data with bigger timeout?
That issue has been added to the backlog. If it is needed by a certain time, we could implement it for some fee. Otherwise, we will do it ourselves, but it is not known by what date.
MikhailModeratorTry create similar report that retrieves data from *.dat archives based on files.
According to the log file, the web app cannot receive data from the SCADA-Server service. May be data is too large. How many data points do you expect for that report and period of time?
PostgreSQL should be configured to allow password authentication. Check this link, for example.
MikhailModeratorThe
Timestampvariable is not available in v5. UseDateTime.UtcNowinstead.-
This reply was modified 1 year, 5 months ago by
MikhailModerator1. Find and stop the application that uses port 10000.
2. Install Rapid SCADA.
3. Change TCP port used by Rapid SCADA.
4. Start the app that uses port 10000.OR
1. Change the port of that app that uses port 10000.
Please check the error details in ScadaWeb.log
MikhailModeratorCool!
November 4, 2024 at 7:44 am in reply to: Hello World Tutorial – “The requested view is not specified” #15568
MikhailModeratorOK
MikhailModeratorRapid SCADA supports MQTT out of the box.
MikhailModeratorPublished at https://rapidscada.net/store/Module/en/ExtScriptCompilerJP
Kepware should support Bacnet. However, you should look for less expensive alternative.
MikhailModeratorHow the new software module will be related with Rapid SCADA?
