How/where could I see/configure more than the last 9-10 events?
Use SCADA-Web Configurator -> Visible events count
How can I easily do an event sent an email ? Do I need to create a rule on Autocontrol for each channel
Yes, you should create a rule. If it’s enough to receive the same message, you can create some kind of aggregation channel. In case of using limits, you can specify trigger on status.
Where are they stored (in case you need to delete ie… 100’s) ?
See directory settings of SCADA-Server.
MikhailModeratorFixed. Thank you for the bug report.
MikhailModeratorYes. Download Rapid SCADA Mono. Manual is made for Debian.
But in the current version schemes are not accessible. The new web app is OK.
MikhailModeratorHmm in the place of the event window? Or alongside the event window?
Custom Data window. Events closes when another window is shown.
In any case a minimize button for the new window if there is one and a minimize button for the event window would be nice.
It exists – the gray circle with arrow.
the event window will automatic open again when a new event happens
Notifications like Skype would be nice, but not in beta version.
MikhailModeratorLet’s join the discussion http://forum.rapidscada.org/?topic=new-web-app-idea
can i run RapidScada in a virtual server in Azure or Amazon?
Yes. Talking about Azure, you have to use virtual server for SCADA-Server and SCADA-Communicator and you can use Web App for SCADA-Web.
Does the licenses for ACM (Automatic Control Module) and Chart Pro/List work on those?
Yes.
If you try Amazon, please tell about the experience.
MikhailModerator
MikhailModeratorDo you have any idea about http://forum.rapidscada.org/?topic=new-web-app-idea ?
This checkbox works for command triggers only.
The feature of inserting dynamic text is not supported by Auto control module for now. It is in the plans.The specified feature will be possible when the module can send command via output channels. In this case using a formula you could generate any text.
May 17, 2016 at 6:48 am in reply to: "Application Error: Unable to Load View" Error Windows 10 #1188
MikhailModeratorThank you 🙂
This is not a bug. The directory of the view set must be correct. It can be set by SCADA-Web Configurator. I’m used edit files.
MikhailModeratorI will check.
Is there any additional info in C:\SCADA\ScadaAdmin\ScadaAdmin.err ?
MikhailModeratorI’m sorry to say that I don’t agree with your decision on keeping with binary data but… OK.
May be the source code should be refactored to allow switching the storage.
MikhailModeratorWhich parameter controls this?
SCADA-Server -> Minute data -> writing period
May 16, 2016 at 6:19 am in reply to: "Application Error: Unable to Load View" Error Windows 10 #1180
MikhailModeratorYou have to specify
<ViewSet name=”Home Meters” directory=”Servers\”>May 15, 2016 at 7:18 am in reply to: "Application Error: Unable to Load View" Error Windows 10 #1175
What are the current full paths of your *.tbl on the disk?
Also post here a content of C:\SCADA\ScadaWeb\config\ViewSettings.xml -
