Viewing 15 posts - 4,981 through 4,995 (of 6,219 total)
  • in reply to: Refresh time #3142
    The refresh time is the same for all the parameters. All the data are received by a single web request. Otherwise, would be not optimal. Use the smallest value of refreshing.
    in reply to: How can I do? #3141
    You should develop your own formulas that calculates average values and reset them when needed. You should enter the formulas into the Formulas table in Administrator and use them from input channels. Also you can purchase creating such formulas.
    in reply to: Roadmap #3137
    Definitely, very useful advice. Thanks!
    in reply to: Roadmap #3136
    If you decide to start a new development using Rapid SCADA as a platform, I think, we should discuss it, may be I can do advice based on the user feedback.
    in reply to: Roadmap #3135
    Thank you! I hope, I will do such section in the future. Currently let’s communicate here. Please create new topics if they are not related to the subject of the current topic.
    in reply to: Email sender bug #3134
    Thank you. I added this bug to the tracker.
    in reply to: PDF Reports #3133
    Can you provide a screenshot?
    Use styles:
    colStyle="col-lg"
    colStyle="col-sm"
    colStyle="col-xs"
    in reply to: SCADA Comunicattor – Events not received #3132
    You have a one input channel for a one tag.
    Event must be bound to a tag that is bound to a channel to be passed to Server.
    in reply to: SCADA Comunicattor – Events not received #3123
    I can’t see important data on the screenshot, because it’s cropped. Can you find that file in C:\SCADA\ScadaComm\Log and paste it here?
    in reply to: Scheme Editor #3122
    Zindex is an order of components one above another when they overlap. Use it for moving back and forward.
    in reply to: Email sender bug #3121
    Could you determine where the bug makes effect? Can you send email with that sign from Communicator?
    in reply to: Roadmap #3120
    Can you tell something more detailed about the configuration database?
    It is difficult to specify the task for now. I am thinking about different approaches. May be we can store the configuration database in XML as a part of the project. It allows easily push it to Git and track changes. And we can use SQLite only for editing purposes as a temporary storage.
    Contribution would be great! What do you think about development of a server module or a device driver? The API is mostly ready and will not be changes significantly. Do you familiar with mobile development? Many users ask for native mobile application. Also interesting are simple constructors for configuring that generate all the settings automatically.
    in reply to: Roadmap #3111
    Thanks for the question.
    Primary task for 2018:
    – Create new components for schemes.
    Possible tasks for 2018:
    – Update Chart Pro plugin. We need different Y axis, possibility to place graphs one above the other.
    – Create module that automatically generates reports by a schedule and sends them by email.
    – Develop the single configuration environment for Rapid SCADA that can manipulate with many projects, connect to remote server to download/upload configuration. It will replace Administrator, Server and Communicator shells.
    Future tasks:
    – Update the structure of the configuration database. Get rid of MSSQL Compact.
    – Make Server independent from a type of data storage.
    – New drivers: OPC UA, BACnet, etc.
    • This reply was modified 8 years, 2 months ago by Mikhail.
    in reply to: Email sender bug #3109
    You can generate events manually using Server. Can you reproduce the error by creating an event such way?
    in reply to: Averaging values #3108
    Good 🙂
