Viewing 15 posts - 4,381 through 4,395 (of 6,219 total)
  • in reply to: How long the ScadaCommCtrl's log is saved ? #4774
    When the log is more than 10 MB, it starts from the beginning. Currently, there is no option to change the max. log size.
    in reply to: Administrator does not run #4773
    These are
    SSCERuntime_x86-ENU.msi
    SSCERuntime_x64-ENU.msi
    You should install both of them.
    in reply to: Extra Scheme Components Plugin #4768
    Thanks, I will check.
    Can you tell the version of the Webstation app and of Extra Scheme Components Plugin?
    in reply to: Values sent from virtual MQTT devices not shown in Webstation #4767
    I suppose, this issue needs debugging. You can do it by yourself or contact the author of the driver on GitHub.
    in reply to: Change Led colour #4761
    How to set condition in rapid scada scheme for the led indicator regarding to the formula above?
    You need to create an new exrta channel in Administrator and bind a led to the new channel.
    in reply to: Change Led colour #4760
    Val(n) is described here.
    Expression a ? b : c is usual for C++/C# and means if a then return b else return c
    in reply to: Use WORDSWAP #4759
    Can you provide an example?
    in reply to: Values sent from virtual MQTT devices not shown in Webstation #4758
    Thanks for the screenshot.
    In the screenshot we see that /input/601 is bound to the channel #601 (because of the number in the Channel column). If there is no “15” in the UI, open the SCADA-Server shell, go to the Current Data node, open current.dat and view the current value of 601 channel. Is it 0 or “15”?
    in reply to: Send Setpoint value (float number) #4754
    When you send a command from Webstation, it goes to Server and can be modified by formula. Server passes the command to Communicator. When you send a command from Communicator, there is no calculations.
    in reply to: Values sent from virtual MQTT devices not shown in Webstation #4753
    Please post a link to a screenshot of the appropriate Device data tab of Communicator.
    in reply to: Extra Scheme Components Plugin #4749
    OK 🙂
    in reply to: pure data & logic linux box distribution #4745
    I am wondering what can be shaved from the OS work load (and the SCADA installation) if all I need is the ScadaComm & ScadaServer, with no need for ScadaWeb / Interface / ScadaTable etc.
    In case of Windows installation, tick Server and Communicator checkboxes.
    Interface folder is required by SCADA-Server, because it provides views to the web app.
    in reply to: pure data & logic linux box distribution #4744
    So, on Linux if I do not need the web server, which steps can I safely skip during the installation process?
    See install_with_apache.txt
    Skip steps 3, 7, 8, 9, 10, 11, 15
    in reply to: Extra Scheme Components Plugin #4742
    Please post here version of the Webstation app and version of Extra Scheme Components Plugin.
    Look the log file in SCADA\ScadaWeb\log for additional error description.
    in reply to: DBExport problem with Calculated real #4738
    Calculated channels are ignored by the export module because they are recalculated many times in a second.
    Unable to enqueue current data
    You should check ModDBExport.log file to find the error cause.
