MikhailModeratori can’t debug
What do you mean in particular?
Please check registration on http://localhost/Scada/plugins/Registration/Registration.aspx?prodCode=PlgSchExtraComp
MikhailModeratorJust use any online translator.
I still can’t find the ScadaServerSvc.exe
C:\SCADA\ScadaServer\ScadaServerSvc.exe
I attach the ScadaServerCtrl.exe,but failed to debug.
You have to build the project in Debug configuration. You should look for some debugging manual of VS.
i want to know where to find scada_5.x.x_full_en.zip
When you download Rapid SCADA from https://rapidscada.org/ you will download this file.
I hope this protocol description helps you. Please use a translator.
See the Comm class.
We create all the documentation files in HTML format, because PDF is not efficient for changes tracking. You could save the online documentation into PDF using a browser.
MikhailModeratorMaybe I will reinstall the Rapid Scada.
Try reinstall Webstation only.
If it doesn’t help, send a screenshot where we can see version of the installed plugins.
Please contact me by info@… I will send the cost offer.
I have no access to the images. Please check them.
MikhailModeratorCurrently, we use English names and write new comments in English.
“Srez” means snapshot or slice. This is the Russian word. Because it is used in many projects and files, difficult to change the name of the class and variables.
MikhailModeratorHi Hugo,
We can do the required feature for a free. If you interested, write an email that contains detailed requirements. And we would estimate the cost of development.
why “%256”, “/256”,what it is doing, I really do not understand.
Gets lo and hi bytes of the integer.
