MikhailModeratorDid you download 5.7.0?
Please provide more information how to reproduce to problem related to events. What plugin raises the error?
Please provide a screenshot.
MikhailModeratorI’ve just checked, the files are available. Strange.
I suggest Rapid SCADA 5.7.0.
What version do you download?
Where do you from?
Please try to do it using another PC.
> Please where can we define event instructions?
Please ask particular questions on the forum, and we will explain how it works.> how can we add user comments when acknowledge an alarm
Currently, this feature is not implemented.
C:\SCADA\ScadaComm\Log also contains lineXXX.log.bak, where you can find the previous part of the log. But this is also a part of log, not full.
May be we should add the option to set the log file sizes.
MikhailModeratorPlease provide a screenshot with device settings for gmail.
I don’t think that timeout really make sense.July 7, 2019 at 7:15 am in reply to: Digital Counter and calculate elapsed time for a channel in certain state #5684
Other approach is creating your own formula (in the Formulas table) like this
public double CalcSwitch(int counterCnlNum) { if (Val() <= 0 && Cnl > 0 && CnlStat > 0) { SetVal(counterCnlNum, Val(counterCnlNum) + 1); } return Cnl; }Use this formula in the channel 114: CalcSwitch(115)
where 115 is the channel for counting, its type is Calculated real.
Note: I don’t test formulas on the forum. May be you need to fix it.July 6, 2019 at 10:22 am in reply to: Digital Counter and calculate elapsed time for a channel in certain state #5680
Try the following:
The new channel of the Switching counter type should have a formula Val(114)
Its Signal field is not set.If the above doesn’t help, please provide a link to the screenshot of the Input channels table.
July 5, 2019 at 1:30 pm in reply to: Digital Counter and calculate elapsed time for a channel in certain state #5678
A channel of the Switching counter type increases by 1 when the channel changes from 0 to 1 and from 1 to 0.
You should check it using the Generator feature when Communicator is stopped. Please write here about the result.
MikhailModeratorTake into account that
CnlStat – the status that was just received from Communicator
Stat(N) – the current status of an input channel before receiving new status
Main Menu > Deploy > Upload Configuration
And the similar button with a small green arrow on the toolbar.
MikhailModeratorSince Rapid SCADA 5.7.0 we store the configuration database in XML as a part of a project. *.dat files are used in runtime.
This reply was modified 6 years, 9 months ago by
MikhailModeratorWhere can i find and/or change the version number?
Usually in the about page. Version number of what application?
Also is it possible to acces the db like a sql datebase or?
Is the baseDat the only thing i have?You can read the files like written here , get data from Server by TCP and use REST API.
