Thanks for noticing.
MikhailModeratorHow does the web interface of the camera work?
Try to create your own simple web page, which includes the video tag, according to this.
Does it work if you paste the URL into the browser address bar?
It depends on browser. You should try. Please share your experience here.
October 30, 2019 at 2:01 pm in reply to: Schedule function and screen editing alignment function #6025
MikhailModeratorWhat kind of actions or commands do you need to schedule via web interface?
> alignment
I agree. This would be very useful.
MikhailModeratorMe too. Sooner or later.
MikhailModeratorUser is optional. Probably, changing user somehow updated the output channel number.
The problem is that the destination folder is not empty.
1. Uninstall Rapid SCADA
2. If the folder C:\SCADA exists, delete it.
3. Install Rapid SCADA from the beginning.
Nice to hear)
MikhailModeratorThe module version is fresh.
The line in the log “Command is enqueued to be sent at 16:10:49. Device 0, Command 1” says that output channel number was not applied.
Try checking C:\SCADA\ScadaServer\Config\ModAutoControl.xml
Other way, in the trigger settings instead of output channel, specify the device number.
Also I can fix this remotely for a fee if needed.
MikhailModeratorRefusing connection can be done by the device itself, by network equipment or firewall.
You can also try to connect by Hercules.
MikhailModeratorPing is not a connection to TCP socket. You should try the advice in the previous message.
MikhailModerator
MikhailModeratorHow to migrate to the new version https://yadi.sk/i/CIcov9Xjbha-NQ
