Viewing 15 posts - 3,721 through 3,735 (of 6,218 total)
  • in reply to: Cannot see installed schemes extra components module #6707
    OK )
    in reply to: step by step method to upload files to raspberry pi #6706
    You should use ScadaAdmin user to connect. Check that ScadaAdmin exists in the Users table.
    in reply to: step by step method to upload files to raspberry pi #6698
    In RPi find the file /opt/scada/ScadaAgent/Config/ScadaAgentConfig.xml
    The secret key in the file must be the same as the secret key in the configuration profile.
    In Administrator you should export the User table to user.dat and copy to /opt/scada/BaseDAT
    To get more info about error, see /opt/scada/ScadaAgent/Log/ScadaAgent.log
    in reply to: Switching between schemes #6697
    In this case, it’s better to set View ID property of the link than URL.
    in reply to: MYSQL and MQTT connection #6696
    I think, you should use real physical machine, because performance of a virtual machine is unpredictable.
    What database model do you use?
    Please create a different topic to discuss MQTT. One subject is a one topic.
    in reply to: step by step method to upload files to raspberry pi #6691
    In Rapid SCADA v5.8 it’s easy to transfer the configuration.
    You should create a new deployment profile in Administrator. Set RPi’s IP address and other profile parameter. Then upload the configuration to RPi. Don’t forget that in Linux you need different directories for SCADA-Server. Before switching from Windows to Linux, change the directories in Server configuration (using Administrator).
    in reply to: Hide / Show or Enable/disable component #6690
    Agree this is a useful feature. We keep it in mind.
    Now it works only for the Button component.
    in reply to: Realtime DB access and indication #6686
    Then vice versa, delete /opt/scada/ScadaServer/Mod/Mono.Security.dll and restart the Server daemon.
    in reply to: Realtime DB access and indication #6684
    Try the following:
    1. Download Mono.Security.dll.zip.
    2. Put the DLL into /opt/scada/ScadaServer/Mod
    3. Restart the Server daemon
    in reply to: Realtime DB access and indication #6679
    To get quick results with export data to PostgreSQL, it would be useful to involve our team in the project. We can help to fix the export process, and upgrade the export module if necessary depending on the requirements.
    in reply to: Realtime DB access and indication #6678
    show realtime data on a chart contionously, without refreshing the webpage?
    We work on it now. Coming soon ))
    You can contact us by email to get early version for testing.
    We are trying to build up a system based on Rapid SCADA to design a mass ventilator system for treatment of group illnesses, specifically to COVID19.
    Wow
    in reply to: Realtime DB access and indication #6677
    Hello Roland,
    Unable to enqueue current data. The maximum size of the queue 100 is exceeded
    2 main possible reasons:
    1. Query is too slow comparing with the amount of incoming data
    2. There is a database error.
    You should analyze the log ModDBExport.log written by the DB export module. You could provide the log here.
    in reply to: DemoProject not working #6676
    The project DemoProject.en-GB.rsproj requires Modbus device or Modbus simulator. Watch the video.
    Version history
    in reply to: Disable / Hide toggle #6672
    Set the formula of the output channel like the example below.
    Val(101) >= 100 && Stat(101) > 0 ? Cmd : double.NaN
    If the formula returns double.NaN, command is cancelled. And you will see an appropriate message in the Server log file.
    in reply to: DemoProject not working #6671
    What version of Rapid SCADA have you installed?
    What is project name that you deployed?
