Viewing 15 posts - 3,136 through 3,150 (of 6,219 total)
  • in reply to: OPC no values #8387
    Connecting to a computer by remote desktop (or similar tools) is a paid service.
    I can help you for free if you open access to OPC server, so I can run OPC UA client on my computer to debug. To do this, you should configure port forwarding on a router.
    in reply to: Forwarding the Rapid scada web on Ubuntu #8386
    To make the web application available from the internet you should open the port 80 for HHTP and port 443 for HTTPS. You should search how to open these TCP ports on Google cloud.
    in reply to: l #8381
    No. But scheme templates may help (scroll the page down to Scheme Templates).
    in reply to: Scada Agent error #8378
    It may be an access rights problem.
    When link is created, it works similar like copying files into the target directory.
    in reply to: sec data save #8377
    I also suggest to map log directories to RAM disk.
    in reply to: Custom Page #8376
    Use getCurCnlDataExt function. If you run file search of “getCurCnlDataExt” on *.js files, you will find examples in the Table and Scheme plugins.
    in reply to: Export to SQLite #8375
    SQL requests are executed by the module every time when data are sent from Communicator to Server. So the logic to store data with particular interval should be implemented on the DB level.
    However, in 2021 we plan to release an update of DB export module to be able to upload Rapid SCADA historical archive to a DB. This feature may be useful in your case.
    in reply to: rapidgate module bug #8374
    Also needed C:\SCADA\ScadaServer\Log\ModRapidGate.log
    I’m sure, this issue can be fixed, and I’ll help to do it.
    in reply to: OPC no values #8373
    I can help you if you provide remote support for the OPC server for testing. Is it possible?
    in reply to: Modbus RTU comunication issue #8372
    Please provide screenshots of the communication line settings and log with errors.
    in reply to: l #8358
    Question:configure the link component, the second-level dialog box does not display data, and no pop-up box appears when the button is clicked.
    Please make a screenshot of the dynamic text properties that is located on the popup. Did you set the Input channel property of this component? It’s required to show values.
    there is something wrong…
    The question is duplicated.
    in reply to: Scada Agent error #8356
    Try repeating the installation steps related to the web application.
    in reply to: Export to SQLite #8355
    I think you should choose one of the native supported databases.
    in reply to: Export to SQLite #8354
    DB Export Module natively supports MySQL, PostrgeSQL, MS SQL and Oracle.
    There is a chance that it’s possible to use Sqlite with help of OLE DB provider. To check it, you need to try setup a connection by Server Explorer of Visual Studio and then copy a connection string.
