MikhailModeratorLikely, 2810 signals is caused by data length overflow. You should try 4500 signals.
MikhailModeratorAfter a polling session is finished, Communicator sends data to the Server app. It sends data device by device. Usually it sends only modified data (it depends on the configuration). So when you split devices, it sends data correctly.
However, the limit of 2810 signals should not be the maximum. I expect that the max. is 4680 according to the binary protocol between Communicator and Server.
Could you check if there are any errors in Communicator and Server log files?
MikhailModeratorFor Modbus salve in Linux VM, you will need to change port number to larger than 1024, e.g. 1502.
Are there any limits on port number?
Most often, computer code changes when a set of MAC addresses of the PC changes. If a license key is bound to a MAC address that is still presented, key continues be valid.
MikhailModeratorThank you for asking. It indicates that this feature is needed for the users.
Method calls currently not supported. Probably, they will be added in the future.
If you need this feature on time, we could implement it according to a contract.
What Rapid Gate version do you use? What is your configuration?
This link contains Webstation version: http://localhost/scada/About.aspx
April 21, 2021 at 2:27 pm in reply to: How to uninstall a rapid scada software in Raspberry Pi? #8804
Clear browser cache and press Shift+F5 on the pages that don’t work.
MikhailModeratorThe manuals and the forum complement each other.
April 20, 2021 at 1:07 pm in reply to: How to uninstall a rapid scada software in Raspberry Pi? #8800
Chart Pro 5.1.0.1 requires Rapid SCADA 5.8.2.
I suggest to upgrade Rapid SCADA to the latest version.April 19, 2021 at 1:54 pm in reply to: How to uninstall a rapid scada software in Raspberry Pi? #8791
What is the version of Webstation?
What is the version of Chart Pro?
Please provide screenshots that contains versions.
MikhailModeratorI recommend to configure a project on Windows, then upload it to a Linux machine.
