Viewing 15 posts - 2,941 through 2,955 (of 6,219 total)
  • Mikhail
    For the current moment I don’t understand how Rapid SCADA should behave according your task.
    in reply to: scheme editor #8949
    Nice 🙂
    I’m curious, what if many event are coming into a moment? How does it sound?
    An I understand you correct:
    When a button in Rapid SCADA is clicked, you need to send a static predefined sequence of bytes? And no response from device to Rapid SCADA?
    in reply to: event triger #8947
    Glad to read this 🙂
    in reply to: OPC on Remote PC #8946
    Both A and B computer’s fire wall are off
    Port 10000, 10001, 10002, 10010 are opened
    Please check the connection using telnet or any other utility (e.g. Hercules).
    Just try to connect via port 10000.
    in reply to: OPC on Remote PC #8945
    Hello Steven,
    Error Connecting to SCADA-server: No connection could be made because the target machine actively refused it 192.168.10.111:10000
    This error is usually caused when firewall of the server machine blocks incoming connections to the port 10000.
    I strongly suggest to move from classic OPC DA to modern OPC UA. It works much better in network environment.
    It’s better if you draw a diagram of the system, and show which communication protocols are used on different architecture levels.
    in reply to: event triger #8937
    1. Set Signal to blank
    2. Update the formula to GetBit(Val(1001), 0); GetBit(Val(1001), 0) > 0 ? 116 : 115
    in reply to: scheme editor #8933
    @q383186554, your developments are quite interesting.
    When you create a production version, let the people know about that.
    in reply to: scheme editor #8932
    will the V6 version save current data per second?
    It will write data to archives with any period.
    I have a new idea about the scheme editor. the web station does not have self-adapting in different screens on different DPI. do you have a plan to solve that?
    It is not a scheme approach. I would call it dashboards. The existing Dashboard plugin also uses Bootstrap. Welcome the creation of different types of views.
    Is the transmitter manual available?
    in reply to: event triger #8930
    The formula is incorrect. Could you provide a screenshot of all properties of this channel?
    in reply to: Cant even login Raspberry Pi 4B Ubuntu 21.04 #8929
    Internet Explorer is not supported. You should use modern browsers like Chrome, Firefox or Edge.
    in reply to: scheme editor #8912
    The mentioned drivers and modules are very useful. That’s great!
    Are documentation or videos available?
    Do you have plans to spread the modules?
    in reply to: event triger #8911
    May be events are created but not displayed. Did you click “All Events” button of the events table?
    Also you should open the archive files in Administrator and check if events presented or not.
    If you change language to English, open channel properties form, and make a screenshot of all channel properties, it would help.
