Viewing 15 posts - 2,911 through 2,925 (of 6,219 total)
  • in reply to: DbImport module missing channel data #9037
    In the debug log I see some channels with >50% empty rate, those channel have signficantly less data in database analysis. While the graph in RS webstation shows complete dataset for these channels.
    Could you provide data examples?
    Will the new plugin be pushed to scada git repo?
    Yes.
    in reply to: Database SQL usage #9032
    Something like
    insert into mytable field1 values (@cmdVal)
    A command contains only one value.
    You should try. In case of errors, you could send links to screenshots and post logs.
    in reply to: Redundancy #9031
    What is the source of the text “The standby server does not duplicate the primary server’s functions…” ?
    To implement the described mode, there should be a separate supervisor service that switches servers. We can develop it if needed by a custom contract.
    in reply to: DbImport module missing channel data #9030
    We will release a fully new ModDbExport which can insert several channels in a one SQL request. My suggestion is to wait for the release.
    in reply to: Redundancy #9023
    Currently there are the following options:
    1. Manually start and stop Communicator services on the servers.
    Data transfer can be performed by Rapid Gate module.
    2. Use 2 servers in parallel. Both of them poll the devices. To do that, you need a hardware gate that allows multiple connections. Like Modbus TCP gates.
    In the future, switching logic may be implemented by Auto Control Module be sending start/stop communication lines commands.
    in reply to: Event Log #9022
    I suppose, the default event panel is meant.
    @123abc56
    , thank you for the ideas. Will see what we can do in v6.
    in reply to: Database SQL usage #9021
    There is also ModDbExport module. You should compare it with KpDbImport.
    in reply to: Database SQL usage #9020
    Microsoft SQL Server definitely provides a current time function. You should google it on database forums.
    If you use KpDbImport for sending commands, it supports @cmdVal and @cmdNum parameters of the SQL statement for command value and command number.
    What is the generalized task you need to resolve?
    in reply to: Redundancy #9014
    Please provide detailed requirements for redundancy that you need.
    in reply to: Database SQL usage #9013
    What module of Rapid SCADA do you use to execute this SQL request?
    What DBMS type?
    in reply to: Send/Import data with timestamps from a driver #9012
    Interesting. Is the C# library is fully written in C# or just a wrapper for C library?
    GPL requires you to provide the source code of your driver. If you do this, I suppose it’s compatible with Apache-2.0.
    in reply to: Send/Import data with timestamps from a driver #9006
    The KPLogic class contains AddArcSrez method. The example is here
    Do you use some library that implements IEC60870 or implement the protocol from scratch?
    in reply to: Communicator will be stoped after Upload Configurations #9004
    Nearly 90% of devices are using Modbus Driver,and another is OPC UA.
    Good.
    You provided the Communicator log. What is in the Server log at the same moment when a problem occurs?
    in reply to: Communicator will be stoped after Upload Configurations #9001
    Can you reproduce this issue using the built in drivers, like Modbus Driver?
    in reply to: Current data updated automatically #8998
    Also change WriteCurPer to 1 in the Server configuration.
