Viewing 15 posts - 2,836 through 2,850 (of 6,219 total)
  • in reply to: Installation failure #9271
    You could also ask in this new subforum.
    in reply to: scada 3d develop #9270
    Very cool!
    in reply to: How to use Notification plugin? #9269
    whatโ€™s the function of tag?
    IDs of the quantities to show in the notification panel.
    Is it possible to limit the notification to certain channels only?
    No, only the filters presented in the configuration file.
    Is is possible to have event on status 4 changed?
    Could you explain this question?
    Note: Notification plugin does not work on Linux because of Mono bug. The web app hangs.
    in reply to: Installation failure #9268
    I don’t understand what is written in Chinese.
    Run services.msc and make sure that ScadaServerService exists in the list.
    in reply to: scada forum #9262
    I’ve kept the both branch names.
    in reply to: Installation failure #9259
    I mean, what do you get in command window when execute *.bat files?
    in reply to: scada forum #9254
    Let’s try ๐Ÿ™‚
    I granted rights to you, but I’m not sure how they work. If there will be inappropriate statements, advertisement or spam, let me know.
    in reply to: Installation failure #9253
    asp.net 4.6, wile my PC is asp.net 4.8
    It’s OK.
    What did you get exactly after the actions below?
    7. Register ScadaServerService by executing ScadaServer\svc_install.bat as administrator.
    8. Register ScadaCommService by executing ScadaComm\svc_install.bat as administrator.
    9. Register ScadaAgentService by executing ScadaAgent\svc_install.bat as administrator.
    in reply to: scada forum #9242
    It would be very useful. I will create a forum branch in the nearest days.
    in reply to: Installation failure #9241
    To fix installation do the items 7-9 by this link.
    In case of errors, provide info.
    in reply to: scada forum #9238
    Do you mean to open a branch for the users who don’t speak English?
    in reply to: SCADA V6 #9236
    The v6 is under active development, and not released even Alpha, so it’s OK. Debug by yourself if interested.
    in reply to: grafana ifame #9235
    ๐Ÿ™‚
    in reply to: Communication with Multiple Devices #9234
    Please start a new topic for this issue and provide screenshots of the settings.
    in reply to: grafana ifame #9229
    Look for Frame component in Extra Scheme Components
