MikhailModeratorScreenshot of the Interface table is required.
MikhailModeratorPlease make a screenshot or copy a communication line log: Line Stats – Line Log
Does the Kepware server support OPC UA?
MikhailModeratorInteresting! Thank you.
Could you describe what it is?
The above link doesn’t work. Please fix the link.September 6, 2021 at 11:25 am in reply to: I can’t connect rapid scada with arduino OPC server #9498
You should install OPC Core Components available at https://rapidscada.org/download-all-files/
Please try this update. Does it help?
MikhailModerator🙂
MikhailModeratorPlease try the KpMqtt update. Does it help?
MikhailModeratorIt makes sense. Thanks.
MikhailModeratorCurrently, it possible to do
KeepGoodVal(); KeepGoodStat()and add in the Formulas table:
public double KeepGoodVal() { return CnlStat > 0 ? Cnl : Val(); } public int KeepGoodStat() { return CnlStat > 0 ? CnlStat : Stat(); }
MikhailModeratorI think, such textbox makes configuration overloaded with options. In the future, it will be possible to make a simple formula included in the software by default.
For example: KeepGoodValue()
MikhailModeratorCould you make a screenshot of the report result?
If you use the default ElasticRepExample.xml, are there min and max?
MikhailModeratorPlease provide the communication line log from server restart to “Error reconnecting” message.
This reply was modified 4 years, 7 months ago by
MikhailModeratorI will check and write in this topic.
