Viewing 15 posts - 2,296 through 2,310 (of 6,243 total)
  • in reply to: My formula #10987
    Possible formula:
    Cnl; Cnl>0?4:CnlStat
    in reply to: My formula #10986
    According to the manual, a part of the formula that calculates channel status is followed by semicolon.
    in reply to: More ‘native’ scheme editor #10985
    Scheme Editor is a complex application, that is why is is not planned to make it an extension for the Administrator app as Table Editor.
    In the future, it is possible to choose a one of the following approaches for Scheme Editor:
    1. Make it a separate WinForms app that wraps web browser.
    2. Make it a web app.
    in reply to: export event data to postgres #10970
    Export DB module writes information to log files located in C:\SCADA\ScadaServer\Log
    Check log files for errors.
    Please publish screenshots as JPEG or PNG, not PDF.
    in reply to: If and then implementation #10969
    Please provide a screenshot of Notification plugin that contains visible notifications.
    in reply to: Rapid SCADA 6 Beta #10965
    Currently, there is no such plan. We should think may be it’s possible to add this feature in the future versions. Thank you.
    in reply to: Elastic Report #10964
    I have no info how that formulas work in Excel. Could you provide a description?
    in reply to: If and then implementation #10962
    Do you see notifications in the panel of Notification plugin as displayed here ?
    • This reply was modified 3 years, 7 months ago by Mikhail.
    in reply to: Rapid SCADA 6 Beta #10958
    May I know how can we set the deadband?
    In the channel limit properties (version 6).
    in reply to: Rapid SCADA 6 Beta #10957
    Thank you JW, will check.
    in reply to: If and then implementation #10956
    But I would to have a long beep with the acknowledgement?
    Long beep is possible with Notification Plugin.
    “Checked” column in this screenshot means acknowledgement made by operator.
    in reply to: Elastic Report #10955
    What version of Rapid SCADA do you use, 5 or 6?
    Could you provide an example how a deviation formula should work?
    in reply to: If and then implementation #10946
    Why don’t you try?
    in reply to: Units (set up a new unit) #10945
    You can create a new row in the Unit table that contains: Good;Fair;Poor
    Channel values would be 0, 1 and 2 to display the specified text.
    in reply to: Custom Web Page #10944
    Could you provide a screenshot of the Interface table of the project?
