Units (set up a new unit) Forum Home › Forums › Understanding the Software › Units (set up a new unit) Tagged: Units This topic has 5 replies, 2 voices, and was last updated 4 years, 2 months ago by Mikhail. Viewing 6 posts - 1 through 6 (of 6 total) Author Posts September 23, 2022 at 12:03 am #10889 victorlamParticipant Hello, May I know if the unit(s) can be defined as different status? For example, Good, Fair, Poor etc. Then the input channel can be displayed as Good or Poor according to the value of hte input channel. September 23, 2022 at 9:45 am #10898 MikhailModerator Hi, Which version of Rapid SCADA is in use, 5 or 6? Answer would be different. September 25, 2022 at 4:02 am #10908 victorlamParticipant It is version 5. September 26, 2022 at 11:09 am #10925 MikhailModerator Yes, you can create a enumeration in the Units table. Use “Off-On” unit as an example. September 26, 2022 at 11:27 am #10932 victorlamParticipant Hello Mikhail, Thanks for the reply. May I know if I need to create two units (Enumeration) with two rows. 36 Off 37 On Or I can combine together. What’s the difference using a single row with two states and two states two rows here? Regards, Victor September 27, 2022 at 11:39 am #10945 MikhailModerator Hello, You can create a new row in the Unit table that contains: Good;Fair;Poor Channel values would be 0, 1 and 2 to display the specified text. Author Posts Viewing 6 posts - 1 through 6 (of 6 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
