MikhailModerator🙂
MikhailModeratorMay be you need a kiosk mode of the browser.
Such behavior depends on a browser. In Chrome, if you start full screen mode by pressing F11, it does not exit on page navigation.
Open Config/ScadaInstanceConfig.xml for editing. Set ActiveStorage to PostgreSqlStorage, and restart Rapid SCADA services.
According to the log, the modem does not respond:Receive: no data
You could compare with the previous logs.
Check connection settings.-
This reply was modified 3 years, 3 months ago by
MikhailModerator🙂
Weird. What is written in Agent settings and log?
MikhailModeratorThank you for finding this bug.
Please download and update the plugin again. Now it should work in Scheme Editor also.
Note: plugin registration is not needed for editing schemes.
It’s possible. Click Main Menu – Reports -…
If you delete the existing configuration files, is possible to upload new configuration?
You should update Rapid SCADA to version 6.0.1 to use the components.
What error do you get? Could you provide a log?
Could you make a screenshot of the file and directory permissions and owner?
MikhailModeratorThank you.
MikhailModeratorChart profile has a name and contains chart options. The list of profiles is defined in PlgChartPro_Config.xml
To define a group of trends, you can specify a chart view in the Views table. For example, https://ibb.co/m46125b
