Viewing 15 posts - 181 through 195 (of 6,218 total)
  • in reply to: In terms of usage #17331
    Definitely.
    More info is here
    in reply to: UPC-UA Server Access Control #17325
    A data source configuration file will appear in Communicator – Configuration files, named like DrvDsOpcUaServer.xml.
    in reply to: UPC-UA Server Access Control #17324
    > I guess I would need create multiple UA servers and then set their ports in the xml configs?
    Yes. Click the Properties button to open the data source options. Create a new configuration for for a data source. Find TCP port in the created file. Please let me know about the result.
    > Are you able to explain connection between devices under the communicator vs devices in the configuration database?
    On Server level, there are calculated channels. While on Communicator level, only data received from the devices.
    in reply to: development web plugin-no.1 #17322
    If you ask about installation, file copying is required to ScadaWeb and ScadaAdmin folders.
    in reply to: development web plugin-no.1 #17321
    It’s different. It’s mostly implemented using JavaScript and a bit of C#. See the example here.
    in reply to: UPC-UA Server Access Control #17320
    I suppose, yes.
    Using the Administrator application, in Communicator – Data sources, create several data sources with the DrvDsOpcUaServer driver. Each data source works independently.
    Note that OPC UA server in Rapid SCADA operates on Communicator level. It can access data of Communicator.
    We are planning to implement access to calculated channels on Server level, but it’s in the future.
    in reply to: chartpro issue #17316
    The most likely cause is a change in the computer code due to a change in the computer parameters.
    Please email us a new computer code shown by Chart Pro to check.
    in reply to: how to configure modbus #17315
    I suggest to install Communicator and Agent on the local Linux-based controller to poll the Modbus device. Then configure sending data from Communicator to the cloud server.
    in reply to: manual build Scada, running Scada #17305
    Yes, you right. This is the most optimal way.
    in reply to: How to reset Channel Value on re-boot? #17304
    in reply to: development web plugin-no.1 #17303
    OK
    in reply to: How to reset Channel Value on re-boot? #17297
    So set the channel, the output formula would be SetTempData()
    public double SetTempData()
      MyVal = CmdVal;
      return CmdVal;
    in reply to: How to reset Channel Value on re-boot? #17296
    Try another solution.
    In the Scripts table, declare a variable:
    public double MyVal = double.NaN;
    In the input formula of the channel use:
    MyVal
    Variables are not stored in archives.
    in reply to: Change Time Zone in CsvExport Application #17291
    The CSV export utility is a separate small application which always requires UTC time.
    You can export historical data to Excel using the local time and then save to CSV.
    in reply to: How to reset Channel Value on re-boot? #17290
    101 is a channel to reset.
