MikhailModeratorPostgreSQL is the main DBMS for Rapid SCADA. Therefore, there are special features for this database.
MikhailModeratorYou should create your own stored procedures that fill code and name and use them in the Export to DB module. However, it is not optimal.
In case of using PostgreSQL, you can upload the project to the database, so you can find channel code and name by its ID.
This forum is in English. For using Russian, please write on https://forum.rapidscada.ru/
For some reason, the services were not registered in OS. You should register them manually by executing the items 7-9 from the manual.
Elastic Report supports multiple sections of the same type in a report.
You should check the error details in ScadaWeb.logMarch 16, 2023 at 11:09 am in reply to: archived data more the 30days, it cannot be displayed normally #12247
MikhailModeratorI will try to use the available information. If that’s not enough, I’ll ask.
March 16, 2023 at 7:47 am in reply to: archived data more the 30days, it cannot be displayed normally #12245
MikhailModeratorThank you.
Next week I will try to reproduce the issue, and write about the results here.
MikhailModeratorThe issue is not related to nginx. .NET is not properly installed.
March 15, 2023 at 8:36 am in reply to: archived data more the 30days, it cannot be displayed normally #12237
MikhailModeratorIn the console image, could you switch the second “Console” tab to Console also? And then press F5 to refresh the page and get messages into the console.
MikhailModeratorTo export data to MySQL, use the Export DB module, located in Server – Modules.
I don’t know if MySQL supports XML functions like Postgres.March 14, 2023 at 9:22 am in reply to: archived data more the 30days, it cannot be displayed normally #12229
Thank you for the report.
Could you copy here the URLs from the address bar for the both screenshots?
Press F12 in browser, go to the Console tab, and refresh the web page with incorrect chart. What messages are printed in the console?
MikhailModeratorIn Administrator:
– Open Server – Archives
– Activate the MinCopy archive and configure its options
– Install PostgreSQL and create a database rapid_scada with user postgres and password postgres. You can change password in Config\ScadaInstanceConfig.xml
– Upload the project to run
Custom web page example for v6 has not been developed. You should use main-api.js to get data from a web page.
To export historical data from Rapid SCADA to XML, a converter application should be developed. Another method is export PostgreSQL archive as written here.
MikhailModeratorDoes your device include MQTT broker, or it is an MQTT client?
