kumajaya
Viewing 15 posts - 31 through 45 (of 144 total)
  • in reply to: Buid Rapid SCADA 6 on Visual Studio Code #11265
    kumajaya
    in reply to: Buid Rapid SCADA 6 on Visual Studio Code #11262
    kumajaya
    MonoDevelop create a bit more simple changes with a same packages.config contents:
    @@ -53,6 +53,9 @@
           <Name>ScadaCommon</Name>
         </ProjectReference>
       </ItemGroup>
    +  <ItemGroup>
    +    <None Include="packages.config" />
    +  </ItemGroup>
       <Import Project="$(MSBuildToolsPath)\Microsoft.CSharp.targets" />
       <!-- To modify your build process, add your task inside one of the targets below and uncomment it.
            Other similar extension points exist, see Microsoft.Common.targets.
    @@ -61,4 +64,5 @@
       <Target Name="AfterBuild">
       </Target>
    +  <Import Project="..\packages\Microsoft.NETFramework.ReferenceAssemblies.net48.1.0.3\build\Microsoft.NETFramework.ReferenceAssemblies.net48.targets" Condition="Exists('..\packages
    \Microsoft.NETFramework.ReferenceAssemblies.net48.1.0.3\build\Microsoft.NETFramework.ReferenceAssemblies.net48.targets')" />
     </Project>
    \ No newline at end of file
    Both need a manual nuget CLI command to restore package:
    mono /usr/local/bin/nuget.exe restore ScadaCommon.Svc/ScadaCommon.Svc.csproj -PackagesDirectory packages
    • This reply was modified 3 years, 12 months ago by kumajaya.
    in reply to: Buid Rapid SCADA 6 on Visual Studio Code #11260
    kumajaya
    Yes, we can use VS 2022 to add nuget package Microsoft.NETFramework.ReferenceAssemblies.net48 with a complex change to ScadaCommon.Svc.csproj and packages.config added with content:
    <?xml version="1.0" encoding="utf-8"?>
    <packages>
      <package id="Microsoft.NETFramework.ReferenceAssemblies.net48" version="1.0.3" targetFramework="net48" developmentDependency="true" />
    </packages>
    As a patch to ScadaCommon.Svc.csproj:
    @@ -12,6 +12,8 @@
         <TargetFrameworkVersion>v4.8</TargetFrameworkVersion>
         <FileAlignment>512</FileAlignment>
         <TargetFrameworkProfile />
    +    <NuGetPackageImportStamp>
    +    </NuGetPackageImportStamp>
       </PropertyGroup>
       <PropertyGroup Condition=" '$(Configuration)|$(Platform)' == 'Debug|AnyCPU' ">
         <DebugSymbols>true</DebugSymbols>
    @@ -53,7 +55,17 @@
         </ProjectReference>
       </ItemGroup>
    +  <ItemGroup>
    +  </ItemGroup>
    +  <Import Project="..\packages\Microsoft.NETFramework.ReferenceAssemblies.net48.1.0.3\build\Microsoft.NETFramework.ReferenceAssemblies.net48.targets" Condition="Exists('..\packages\Microsoft.NETFramework.ReferenceAssemblies.net48.1.0.3\build\Microsoft.NETFramework.ReferenceAssemblies.net48.targets')" />
    +  <Target Name="EnsureNuGetPackageBuildImports" BeforeTargets="PrepareForBuild">
    +    <PropertyGroup>
    +      <ErrorText>This project references NuGet package(s) that are missing on this computer. Use NuGet Package Restore to download them.  For more information, see http://go.microsoft.com/fwlink/?LinkID=322105. The missing file is {0}.</ErrorText>
    +    </PropertyGroup>
    +    <Error Condition="!Exists('..\packages\Microsoft.NETFramework.ReferenceAssemblies.net48.1.0.3\build\Microsoft.NETFramework.ReferenceAssemblies.net48.targets')" Text="$([System.String]::Format('$(ErrorText)', '..\packages\Microsoft.NETFramework.ReferenceAssemblies.net48.1.0.3\build\Microsoft.NETFramework.ReferenceAssemblies.net48.targets'))" />
    +  </Target>
       <Target Name="BeforeBuild">
    in reply to: Buid Rapid SCADA 6 on Visual Studio Code #11259
    kumajaya
    I’m not familiar with VS. The compiler try to find .NetFramework v4.8:
    error MSB3644: The reference assemblies for .NETFramework,Version=v4.8 were not found. To resolve this, install the Developer Pack (SDK/Targeting Pack) for this framework version or retarget your application. You can download .NET Framework Developer Packs at https://aka.ms/msbuild/developerpacks
    and add per https://github.com/Microsoft/dotnet/tree/main/releases/reference-assemblies instructions:
      <ItemGroup>
        <PackageReference Include="Microsoft.NETFramework.ReferenceAssemblies" Version="1.0.3" PrivateAssets="All" />
      </ItemGroup>
    fix it.
    in reply to: Buid Rapid SCADA 6 on Visual Studio Code #11257
    kumajaya
    It’s normal because no object reference anywhere yet. In VS Code terminal type:
    dotnet build ScadaCommon.sln -c Release
    You will got your first error because of cross compiling Windows app on Linux, modify ScadaCommon.Forms.csproj like:
        <Copyright>Copyright © 2022</Copyright>
        <EnableWindowsTargeting>true</EnableWindowsTargeting>
    Run again dotnet build, you will got your second error. Edit ScadaCommon.Svc.csproj like:
      </Target>
      <ItemGroup>
        <PackageReference Include="Microsoft.NETFramework.ReferenceAssemblies" Version="1.0.3">
          <PrivateAssets>all</PrivateAssets>
          <IncludeAssets>runtime; build; native; contentfiles; analyzers</IncludeAssets>
        </PackageReference>
      </ItemGroup>
    </Project>
    Run dotnet build again, profit!
    in reply to: Rapid SCADA 6 Beta #11256
    kumajaya
    Yes, I confirm without https endpoints, UAExpert not list https access anymore but Opc.Ua.Bindings.Https.dll still requested.
    To confirm communicator exception, you can watch ScadaComm.log while restart Scada server.
    in reply to: Rapid SCADA 6 Beta #11252
    kumajaya
    Can’t create historical data and event reports because PlgMain.Report.dll not included in ScadaWeb.
    System.IO.FileNotFoundException: Could not load file or assembly 'PlgMain.Report, Version=6.0.0.0, Culture=neutral, PublicKeyToken=null'. The system cannot find the file specified.
    in reply to: Rapid SCADA 6 Beta #11251
    kumajaya
    Still working as OPC UA client and server but in log:
    Resolver could not find assembly 'Opc.Ua.Bindings.Https, Version=1.4.370.0, Culture=neutral, PublicKeyToken=bfa7a73c5cf4b6e8'
        requested by 'Opc.Ua.Core, Version=1.4.370.0, Culture=neutral, PublicKeyToken=bfa7a73c5cf4b6e8'
    Communicator seems like not handle server restart nicely:
    Data source ScadaServer: Error receiving telecontrol commands:
    Scada.ScadaException: Incorrect format of data received from the server: unable to read data packet header
       at Scada.Client.ClientBase.ReceiveResponse(DataPacket request)
       at Scada.Client.ScadaClient.GetCommand()
       at Scada.Comm.Drivers.DrvDsScadaServer.Logic.ScadaServerDSL.ReceiveCommands()
    System.IO.IOException: Unable to write data to the transport connection: Broken pipe.
     ---> System.Net.Sockets.SocketException (32): Broken pipe
       at System.Net.Sockets.NetworkStream.Write(Byte[] buffer, Int32 offset, Int32 count)
       --- End of inner exception stack trace ---
       at Scada.Client.ClientBase.SendRequest(DataPacket request)
    in reply to: Buid Rapid SCADA 6 on Visual Studio Code #11248
    kumajaya
    My previous build still left some native library in place. For a big clean Administrator distribution:
    cd ScadaAdmin/ScadaAdmin
    dotnet publish ScadaAdmin.sln -c Release -r win-x64 --self-contained true -p:PublishReadyToRun=true -p:PublishSingleFile=true -p:IncludeNativeLibrariesForSelfExtract=true
    in reply to: XML Content Translator for SCADA 6 #11247
    kumajaya
    Xct will remove no existence key, add a new key with a pink background cell (a mark for empty translation), but can’t detect content changes.
    in reply to: XML Content Translator for SCADA 6 #11238
    kumajaya
    My modified Xml Content Translator always sync to github for base language 😀 A complete SCADA 6 xml language raw url included. Yes, I’ll make a pull request for Indonesian language support.
    in reply to: Buid Rapid SCADA 6 on Visual Studio Code #11237
    kumajaya
    Don’t worry, Administrator run so smooth on Wine.
    in reply to: Buid Rapid SCADA 6 on Visual Studio Code #11230
    kumajaya
    Scheme editor a bit problematic, the best solution for now run it using mono:
    mono ScadaSchemeEditor.exe
    in reply to: Buid Rapid SCADA 6 on Visual Studio Code #11228
    kumajaya
    Administrator run smoothly on Ubuntu Linux, feel like a native app. With all my patch to github, my publish command to make a single-file executable with dotnet runtime included:
    From scada-v6 source root:
    and Administrator ready for us in:
    ScadaAdmin/ScadaAdmin/ScadaAdmin/bin/Release/net6.0-windows/win-x64/publish
    I believe a fix for crypto problem to make OPC UA client works will come from Wine soon or later.
    • This reply was modified 4 years ago by kumajaya.
    in reply to: XML Content Translator for SCADA 6 #11224
    kumajaya
    Sorry, the correct one:
    <?xml version=”1.0″ encoding=”utf-8″ ?>
    <ScadaDictionaries name=”English”>
    <General>
    <CultureName>en-GB</CultureName>
    </General>
    <!– ScadaCommon.dll –>
    <Dictionary key=”Scada.Application”>
    <Phrase key=”ProductName”>Rapid SCADA</Phrase>
    <Phrase key=”ServerAppName”>Server</Phrase>
    <Phrase key=”CommAppName”>Communicator</Phrase>
    </ScadaDictionaries>
