April 15, 2021 at 1:28 am in reply to: How to uninstall a rapid scada software in Raspberry Pi? #8751
hethongscada62
ParticipantDear All,
Web application setting was configured likes this:
https://ibb.co/HrLnCSj
Where have i to fix?
ThanksApril 15, 2021 at 12:58 am in reply to: How to uninstall a rapid scada software in Raspberry Pi? #8750hethongscada62
ParticipantDear manjey73,
Dear Mr.Mikhail,
Thank manjey73 for your advice. I was tried by your method but can not get a result.
Thank Mr.Mikhail for your reply. I have had the uninstallation in ZIP. Of cause i don’t like to uninstall Rapid SCADA because my project is running perfectly on Windows, all it’s components are running well on Raspberry Pi4 except Chart Pro Plugin.
I don’t know where and how to fix file access rights. For example: “Error saving web application settings: Access to the path is denied.”
https://ibb.co/KbSfmr5
Thanks and best regardsApril 14, 2021 at 12:10 pm in reply to: How to uninstall a rapid scada software in Raspberry Pi? #8740hethongscada62
The some were changed, after save configuration of Chart Pro i have had likes this:
Some where is wrong?
Thanks a lotApril 14, 2021 at 9:40 am in reply to: How to uninstall a rapid scada software in Raspberry Pi? #8737hethongscada62
Yes, i don’t know why. All keys are working well except ChartPro key. Can not save configuration.
You said “you need to change the swap file system to another one.” Could you tell more detail: What is swap file? Where is it locate?
Thanks a lothethongscada62
ParticipantDear Mr.Mikhail,
After writing an access to the configuration directory and configuration file, i can not get the result. Can not save Configuration”. The notices appears likes these:
“Error saving web application settings: Access to the path “/var/www/html/scada/config/WebSettings.xml.bak” is denied.”“Application Error
Details:
Method not found: !!0 Scada.Web.WebUtils.GetParamAsEnum<!0>(System.Collections.Specialized.NameValueCollection,string,!!0)”
https://ibb.co/37SMHdx
https://ibb.co/y8DksVq
Where is the wrong?
Chart Pro Plugin was selected, but can not get the result.
Some screenShot are following:
https://ibb.co/DktzQTb
https://ibb.co/SQmYbTH
https://ibb.co/M2j2v3T
Where is wrong?
Where have i check?
Thanks and best regardshethongscada62
ParticipantHello Mr.Mikhail,
Yes, all keys were selected in the configuration of the web application.
https://ibb.co/T4q9p6q
Thankshethongscada62
The registration key for Chart Pro was configured. That seems is working in Web well.
https://ibb.co/Zm08Msv
But the software have not processed the Chart.
https://ibb.co/fYKCdgr
Could you let me know where is wrong? Where can i check?
From Han Hoanghethongscada62
The registration key for Chart Pro was configured. That seems is working in Web well. But the software have not processed the Chart.
https://ibb.co/19ZFhpg
https://ibb.co/J72mskk
All problems were resolved.
Thank you very much
Thank you for your reply. The problems with plugin modules were resolved. They can be activated now and can get the raspberry Pi codes on the web except ModAutoControl plugin. I can not get a code for ModAutoControl. Could tell more detail steps to get it?
The problem is How to edit Web app settings in the XML file? Which raw in the XML file will be edited?
I want to use AutoControl Module on Raspberry Pi4. So Pls help me to get the Raspberry Pi4 Key for purchasing order.
P/S: On this Raspberry Pi4 was installed the fee Extra Commponent Module. It is working perfectly.
From Hoang Hanhethongscada62
Yes, but the problem is that how to write access rights to /opt/scada/ScadaWeb/config directory, could You help me?
Thank you for your reply.February 10, 2021 at 2:00 pm in reply to: Cannot see installed schemes extra components module #8279hethongscada62
ParticipantDear Mr. Mikhail,
My project on Raspberry Pi4 with paid Extra component plugin module is running well but when i update it the problem appears. I can not activate the Extra component plugin. There was on the screen the notice: “Error saving web application settings: Access to the path “/var/www/html/scada/config/WebSettings.xml.bak” is denied.”
Where is the wrong? Could you let me know?
From Han Hoang -
