hethongscada62
ParticipantDear Mr.Mikhail,
Yes I was tried to send. You can see screenshot bellow:
https://ibb.co/Fs7kSFH
https://ibb.co/PgLKb0r
SMS can not send.
Where is wrong?
Thanks a lot
Han Hoanghethongscada62
ParticipantDear Mr.Mikhail and All.
The Module SIM808 (GSM/GPRS/GPS/BLE Module) is testing now.
https://ibb.co/tQvb70M
You can see a screenshot bellow:
It is not working, it is?
Could You let me know?
Thanks and best regards
ParticipantDear Mr.Mikhail.
Yes, I see the driver KpSms.dll that supports both types SMS command and AT command set for sending SMS, but I did not see a custom AT command text example likes the Sending SMS command text examples:
group_name;message
contact_name;message
phone_number;message
Could let me know a text examples when using custom AT command?
ParticipantDear Mr.Mikhail and All,
Rapid scada can use a Module SIM808 (GSM/GPRS/GPS/BLE Module) for sending SMS?
Han HoangAugust 19, 2022 at 7:07 am in reply to: The frame component can display data from Camera RS485 PTC01A-30 #10495hethongscada62
Thank You for your reply.
Camera in my project now is using WiFi Yoosee. The VLC media player can show via link rtsp://admin:Ha50552337!$$!@192.168.2.72:554/onvif1. The Property URL of frame were configured with above link rtsp. But here was not thing in the frame.
Could You advise me how to do?
Thanks and best regardshethongscada62
ParticipantHi haitan981,
Try to “Clear the browsing data of Chrome”. It maybe can help you to solve that problem.hethongscada62
– The Automatic Control module is using on my project now.
– Yes, the 2 relays are 2 different devices. That’s mean only 1 Button can turn On or Off 2 devices at one.
So how to configure the Automatic Control module?
Thankshethongscada62
Related to this topic” Send command” , can i ask You a question:
Will 2 relays be controlled via only 1 Button?.
That’s mean can the command send 1 value to more than 2 input when the Button clicks?
Han HoangMay 19, 2021 at 2:03 pm in reply to: Which code of RF transmitter 315MHz can Rapid Scada send to RF Receiver? #8970hethongscada62
ParticipantSorry.
This is screenshot is true.
https://ibb.co/dfkqg5H
Thank You againMay 19, 2021 at 1:57 pm in reply to: Which code of RF transmitter 315MHz can Rapid Scada send to RF Receiver? #8969hethongscada62
My Rapid Scada project is running well now. It can control my devices via RF transmitter.
For the current moment I don’t understand how Rapid SCADA should behave according your task.
It is sample. Rapid scada can control devices via Outs as relay. This relay control the Input of RF transmitter. That’s all. You can see my screenshot. Rapid Scada can control all devices at my home. Rapid Scada is great.
https://ibb.co/nD4XfgR
There is bad that have to use many relays.
Thank You for your attention.
Han HoangMay 14, 2021 at 1:47 am in reply to: Which code of RF transmitter 315MHz can Rapid Scada send to RF Receiver? #8950hethongscada62
The sending a static predefined sequence of bytes when a button in Rapid SCADA is clicked have been worked, but not response from device. I think there was the problem with PulseLength. Have to create something likes as a driver or formula?
Thanks a lotMay 12, 2021 at 3:10 pm in reply to: Which code of RF transmitter 315MHz can Rapid Scada send to RF Receiver? #8940hethongscada62
The diagram of the system is sample: replacing a Buttons on RF(or IR) remote controller (garage door, lights, fan,…) by Buttons on Web rapid scada .
For example: The EV1527 chipset in garage door remote uses a 24-bit codeword comprising 20 address bits followed by 4 data bits. The codes have been got from garage door remote are:
Button 1:
Decimal: 8571080 (24Bit)
Binary: 100000101100100011001000
Tri-State: not applicable
PulseLength: 321 microseconds
Protocol: 1
Raw data: 9964,956,332,312,976,312,976,308,980,304,980,308,980,952,340,304,980,956,336,188,908,276,728,264,124,168,308,60,24,60,236,88,88,204,88,76,80,56,1020,284,440,56,24,40,100,84,12,36,56,Button Address Data
Button 1: 10000010110010001100 1000
Button 2: 10000010110010001100 0100
Button 3: 10000010110010001100 0010
Button 4: 10000010110010001100 0001
So can create a driver that sends commands with above data from Rapid Scada directly to RF (or IR) Transmitter part?
ThanksMay 11, 2021 at 3:03 pm in reply to: Which code of RF transmitter 315MHz can Rapid Scada send to RF Receiver? #8936hethongscada62
Yes, the transmitter can be manual available. I am using an Arduino as intermediate driver, so i can control a transmitter via Button on Rapid scada Web to send codes.
But the better is having a driver, ins’t it?
ThanksMay 10, 2021 at 1:36 pm in reply to: Which code of RF transmitter 315MHz can Rapid Scada send to RF Receiver? #8913hethongscada62
Thank you for your reply.
I am not IT developer, so i can not create a driver but i have had a another solution. Are you going to develop it?
ParticipantDear Mr.Mikail,
The email driver was testing. It is running in my project. I configured the email device that can send an email only to single contract. That’s mean i can not configure the device that can send email to group_name. I think there is a problem in creating group_name in the command text. Could you let me know How to create a group_name?
Han Hoang -
