hethongscada62
ParticipantDear Mr.Mikhail,
On the second PC have beeb installed communicator with following configuration:
https://ibb.co/Sv9Kyvq
https://ibb.co/NNyL6s4
https://ibb.co/jZsvrLQ
https://ibb.co/YQGqLgh
https://ibb.co/37jbf00
https://ibb.co/6Ry2Hkt
The result is null.
Where is wrong? Could you let me know?
Note: 02 PC are running on the same network, maybe is this a cause?
Thank you so much again.
Han Hoanghethongscada62
Thank you for your reply.
I tested with 01 communicator. So 02 instances have been created on main server (first PC): Default instance and Remote_1 instance as bellowing:
https://ibb.co/hdj4c7k
https://ibb.co/vQsh1hV
https://ibb.co/J2y9gWn
https://ibb.co/St3Hkb1
When I click Stats, maybe they are running:
https://ibb.co/mvK0rPh
https://ibb.co/KKY3QvL
But I can not upload configuration
https://ibb.co/kBh5XKt
Where is wrong?
Thanks you so muchhethongscada62
ParticipantDear Pieter and All,
I have two instances
Pc A is running the server and whole application.
Pc B is running communicator connected to server of Pc A.
Pc B is reading data from Modbus devices.
Can you explain in detail screenshot how to connect remote communicator to Server and how to configure a server and communicator?
Thanks a lot
The best regards
Can we resolve this problem by configuring a automatic module? That means Automatic sends only a high value.
Thanks a lot
ParticipantDear Mr.Manjey73 and Mr.Mikhail,
The I/O of raspberry pi did not use. I use a raspberry as temporary device (communicator) that collects data then transfer it to server.
The question is following: Can we see the communication device on Linux Version? If we can how to process?
Thanks and best regards
I want to note that the total subjects in this project is 11.
Linux-based PLC is difficult to buy in my country so I did not use in my project.
I thing the internet connection is stable so my solution is following:
1) Related to Rapid Scada software: Will be installed one main Server and 10 Communicator + 10 Agent
2) Related to Hardware:
– 01 Server will be used Dell computer (Dell Optiplex Core i5 2400 / 8G / SSD 120GB) where install main server
– 10 Communicators will be used Raspberry Pi4 model B+
3) The Interfaces will be created 11 Schemes and 11 Tables on the Server Computer.
– How do you think about my solution?
– How will I configure communicators and Agents?
Han HoangApril 26, 2023 at 11:50 am in reply to: Understanding the data exchange between Rapid Scada and MySQL #12502hethongscada62
How to create a new topic?
ThanksApril 26, 2023 at 9:18 am in reply to: Understanding the data exchange between Rapid Scada and MySQL #12496hethongscada62
My testing Rapid Scada project for 1 subject is running perfectly. Now i will build a project for more 5 subjects. For example: 1 center office + 5 warehouses. These subjects are located in difference places. The structure of this project will be created:
– One servers will need where installs a main instance
– 5 communicators where will install 5 communicator
Could you advise me more in detail to build it?
ParticipantDear Mr. Mikhail,
It is now working.
Thank You for your support
The mono.security.ddl was found and deleted. The KpEmail is working normal. The email is sending automatic perfectly, but KpTelegram has not executed.
https://imgbb.su/image/xL80O1
https://imgbb.su/image/xL8zNY
https://imgbb.su/image/xL8xuW
https://imgbb.su/image/xL8v0R
Maybe there is not new Mono.Security.ddl in KP folder.
I am finding online a new version of Mono.Security.ddl but i have not got a result.
Do you have new Mono.Security.ddl file?
The current Mono version is 6.12.0.122.
https://imgbb.su/image/xq0tHS
https://imgbb.su/image/xq0Vq6
I think the current version is not too old but I am trying to update to Mono version 6.12.0.182 but I can not update.
https://imgbb.su/image/xq0O16
Has a another method to update?
Thanks a lot
I have done as you advised. There is strange, all both email and telegram drivers are working perfect on Windows but they can not work on RPi.
https://imgbb.su/image/xTz7FM
https://imgbb.su/image/xTzwyC
Some thing is wrong on RPi, but where is it?
Thanks a lot
Thanks a lot
Han Hoang-
This reply was modified 3 years, 9 months ago by
hethongscada62.
hethongscada62
And there are versions of drivers those are using in my project:
KpEmail: version 5.0.1.1
Kptelegram: version 5.0.2.0
Communicator: version 5.2.1.0
Server: version 5.1
Thanks a lot
Han Hoang -
