manjey73ParticipantIt is allowed to link to html in another resource, for example http://10.2.0.1:8081 but in this case, the javascript of another resource may be blocked inside the frame.
This reply was modified 4 months, 3 weeks ago by
manjey73.
manjey73Participanthttp://localhost:5000/Object_13 What do you have there? the link for the frame?
if I’m not mistaken, you need to place your pages in wwwroot\custom and the link will start with /custom/myHtmlPage.html
Do you want to download the svg directly as a link? I’m not sure that’s going to happen.
You have Images in the project tree, so you should add an image there. Or a more complicated way, use the ExtraMarkup component.
manjey73ParticipantEnter there 10 06 02 02 00 03
And then enter 10 06 02 02 00 03 F2 6A if the byte order in the CRC corresponded to the display of the VALUE in the parser
manjey73Participantthe calculation is correct, but the displayed value is incorrect, since the CRC in Modbus is always inserted the lowest byte ahead.
manjey73ParticipantCheck in the browser (show code) on the i-frame element
manjey73Participant
manjey73ParticipantIn Modbus, the lowest CRC byte always goes first, then the highest.
A feature of the CRC calculation in the Modbus protocol is that if we send a packet along with the CRC to the calculation, we should get 0
manjey73Participantframe can block scripts. But in theory, if it works within the same domain, then everything should work.
See what’s going on in debugging. Perhaps you just entered the wrong link to display in the frame.
manjey73ParticipantThe speedometer can be adjusted to suit your needs. You can replace the background image and arrows there.
manjey73ParticipantThe format should be On-OFF. The error is probably related to the fact that you need to set the byte order correctly. Or set up the address start correctly from 0 or from 1.
May 10, 2026 at 8:56 am in reply to: Modbus Relay Optimization: Using Poll on Command, Device Duplication, and Event- #17936
manjey73ParticipantIt is possible to duplicate the device. And this is the only way at the moment.
For example, you have a myDevice1 device, you create myDevice1_1 and myDevice1_2 and make different polling patterns, for example, a part for fast polling and a second for slow pollingA team survey requires formulas to work.
manjey73Participantthere you need to submit a command so that the gateway sends the data that was available during the period of absence of communication. Perhaps you can write a script on the main server to monitor and calculate the time and use the automatic control module.
April 25, 2026 at 8:15 am in reply to: Issue with Moddif Plugin Modification: Communication Failure and InfluxDB Write #17889
manjey73ParticipantFrom my observations, Server Modules do not have isolation like drivers. A logical error leading to an exception will stop the Server. I tried using Thread and I ran into various problems. After that, I switched to Task, in case of an error in the task, it simply closes.
The bots in the module are called about 10 times per second, it is necessary to take this into account.
manjey73ParticipantScripts can’t transfer data to devices. It is only possible to transfer to the device via the AutoControl Module, which can be configured to work in channels.
I can’t tell you about the broadcast address, probably not than yes. This should be built into the driver and is not so easy to implement (I did this on one device, but not Modbus)
manjey73ParticipantI’m also in favor of a dynamic approach. Maybe there is some way to teach Mimic to work with language files located in the lang folder? and by choosing the right language, would the mnemonic scheme change the labels in the appropriate languages?
