phachakornParticipantto greenfoxx
it Works.
Thanks you.
phachakornParticipantI also encountered the same problem.
This message in Line Log
2019-12-25 13:40:25 Error executing actions of Device 52 “MQTT” on communication line terminating: Object reference not set to an instance of an object.
2019-12-25 13:40:25 Stop communication line 6 “MQTT”
2019-12-25 13:43:47 Initialize communication line 6 “MQTT”
2019-12-25 13:43:47 Error executing actions of Device 52 “MQTT” on adding device to communication line: Could not find a part of the path ‘C:\SCADA\ScadaComm\Config\’.
2019-12-25 13:43:47 Start communication line 6 “MQTT”2019-12-25 13:43:47 Communication session with the Device 52 “MQTT”, type: KpMqtt
Error reconnecting2019-12-25 13:43:47 Communication session with the Device 52 “MQTT”, type: KpMqtt
Error reconnecting
phachakornParticipantIt works.
Solved the problem.
Thanks for the quick advice.
phachakornParticipantI use OS windows server 2012R2
Solved the problem.
phachakornParticipantHi Mikhail.
Thank you for your advice.
My name is Phachakorn
I use Scheme Editor Version 5.2.2.0This is a message from Log file.
2561-09-17 18:17:17 <PNT-PC><PNT><ACT> Initialize common data of Scheme Editor
2561-09-17 18:17:17 <PNT-PC><PNT><ACT> Load components from files
2561-09-17 18:17:17 <PNT-PC><PNT><ACT> Components are loaded from the file C:\SCADA\ScadaWeb\bin\PlgSchBasicComp.dll
2561-09-17 18:17:17 <PNT-PC><PNT><ERR> Error loading the plugin assembly C:\SCADA\ScadaWeb\bin\PlgSchExtraComp.dll:
Could not load file or assembly ‘file:///C:\SCADA\ScadaWeb\bin\PlgSchExtraComp.dll’ or one of its dependencies. Operation is not supported. (Exception from HRESULT: 0x80131515)
2561-09-17 18:17:17 <PNT-PC><PNT><ACT> WCF service is started
2561-09-17 18:28:30 <PNT-PC><PNT><ACT> WCF service is stopped
2561-09-17 18:28:30 <PNT-PC><PNT><ACT> Scheme Editor is shutdown
——————————————————————————–What do I have to do Advise me.
Thanks You.
Phachakorn Tasusee
Head of Automation Department
Quick ERP Co., Ltd.
phachakornParticipanthi
i checked all number of year is 2017 all data but number in WEB table view not show.Do I have to fix anything else?
I do as you suggest. It gives the Hourly file a valid year name (170331.dat) . And in the log file, the year number is 2017.
But in the table on the web SCADA that do not have the numbers.Do I have to fix anything else?
In Thailand, there are two year count systems.
Buddhist era and Christian era.
2560 is Buddhist era count systems.
But in computer i setup Legion and Language format to Christian era.
Do I need to set up another one?I see C:\SCADA\ScadaComm\Log\ScadaCommSvc.log have 2560 year too.
I will try to follow this advice.
“Try opening Control Panel > Administrative Tools > Services and changing the user for ScadaServerService and ScadaCommService”thanks you
phachakornParticipantHI
2560-03-27 15:46:18 <SCADA-PC><SYSTEM><ACT> ScadaServerService 5.0.1.0 is started
2560-03-27 15:46:19 <SCADA-PC><SYSTEM><ACT> Check the existence of the data directories is completed successfully
2560-03-27 15:46:19 <SCADA-PC><SYSTEM><ACT> Check the existence of the configuration database files is completed successfully
2560-03-27 15:46:19 <SCADA-PC><SYSTEM><ACT> Input channels are read from the configuration database. Active channel count: 40
2560-03-27 15:46:19 <SCADA-PC><SYSTEM><ACT> Ouput channels are read from the configuration database
2560-03-27 15:46:19 <SCADA-PC><SYSTEM><ACT> Users are read from the configuration database
2560-03-27 15:46:20 <SCADA-PC><SYSTEM><ACT> Formulas are read from the configuration database
2560-03-27 15:46:29 <SCADA-PC><SYSTEM><ACT> The formulas source code has been compiled
2560-03-27 15:46:29 <SCADA-PC><SYSTEM><ACT> Connection listener is started
2560-03-27 15:46:29 <SCADA-PC><SYSTEM><ACT> Start server
2560-03-27 15:46:29 <SCADA-PC><SYSTEM><ACT> Current data are not loaded
2560-03-27 15:46:32 <SCADA-PC><SYSTEM><ACT> Connect to client 127.0.0.1
2560-03-27 15:46:32 <SCADA-PC><SYSTEM><ACT> The user ScadaComm is successfully authenticated
2560-03-27 22:28:32 <SCADA-PC><SYSTEM><ACT> Connect to client 127.0.0.1
2560-03-27 22:28:32 <SCADA-PC><SYSTEM><ACT> The user ScadaWeb is successfully authenticated
2560-03-27 22:29:27 <SCADA-PC><SYSTEM><ACT> Check user admin name and password. Result: passed
2560-03-27 22:30:57 <SCADA-PC><SYSTEM><ACT> Disconnect client 127.0.0.1
2560-03-27 22:38:02 <SCADA-PC><SYSTEM><ACT> Connect to client 127.0.0.1
2560-03-27 22:38:02 <SCADA-PC><SYSTEM><ACT> The user ScadaComm is successfully authenticated
2560-03-27 22:38:39 <SCADA-PC><SYSTEM><ACT> Connection listener is stopped
2560-03-27 22:38:39 <SCADA-PC><SYSTEM><ACT> Server is stopped
2560-03-27 22:38:39 <SCADA-PC><SYSTEM><ACT> ScadaServerService is stopped
2560-03-27 22:38:40 <SCADA-PC><SYSTEM><ACT> ScadaServerService 5.0.1.0 is started
2560-03-27 22:38:40 <SCADA-PC><SYSTEM><ACT> Check the existence of the data directories is completed successfully
2560-03-27 22:38:41 <SCADA-PC><SYSTEM><ACT> Check the existence of the configuration database files is completed successfully
2560-03-27 22:38:41 <SCADA-PC><SYSTEM><ACT> Input channels are read from the configuration database. Active channel count: 40
2560-03-27 22:38:41 <SCADA-PC><SYSTEM><ACT> Ouput channels are read from the configuration database
2560-03-27 22:38:41 <SCADA-PC><SYSTEM><ACT> Users are read from the configuration database
2560-03-27 22:38:41 <SCADA-PC><SYSTEM><ACT> Formulas are read from the configuration database
2560-03-27 22:38:42 <SCADA-PC><SYSTEM><ACT> The formulas source code has been compiled
2560-03-27 22:38:42 <SCADA-PC><SYSTEM><ACT> Connection listener is started
2560-03-27 22:38:42 <SCADA-PC><SYSTEM><ACT> Start server
2560-03-27 22:38:42 <SCADA-PC><SYSTEM><ACT> Current data are loaded
2560-03-27 22:38:50 <SCADA-PC><SYSTEM><ACT> Connect to client 127.0.0.1
2560-03-27 22:38:50 <SCADA-PC><SYSTEM><ACT> The user ScadaComm is successfully authenticated
2560-03-27 22:39:59 <SCADA-PC><SYSTEM><ACT> Connect to client 127.0.0.1
2560-03-27 22:39:59 <SCADA-PC><SYSTEM><ACT> The user ScadaWeb is successfully authenticated
2560-03-27 22:39:59 <SCADA-PC><SYSTEM><ACT> Check user admin name and password. Result: passed
2560-03-27 22:42:35 <SCADA-PC><SYSTEM><ACT> Disconnect client 127.0.0.1
2560-03-28 18:57:25 <SCADA-PC><SYSTEM><ACT> Connect to client 127.0.0.1
2560-03-28 18:57:25 <SCADA-PC><SYSTEM><ACT> The user ScadaWeb is successfully authenticated
2560-03-28 18:57:34 <SCADA-PC><SYSTEM><ACT> Check user admin name and password. Result: passed
I checked It has a raw hourly data exist.
But there is the inaccuracy of the number of years.
Look at the picture.
Please how to fix
thanks you
This reply was modified 9 years, 7 months ago by
phachakorn.
Thanks for the quick answer.
But my software has run for 48 hours ago.
And now I have not seen any numbers in hour columns.
Please how to fixthanks you
phachakorn.
