Matt3
Viewing 15 posts - 1 through 15 (of 28 total)
  • in reply to: ModDbExport #14389
    Matt3
    Thank you. I will take a look at both suggestions.
    in reply to: Custom Page #14349
    Matt3
    Perfect. Thank you Mikhail.
    in reply to: Custom Page #14224
    Matt3
    Hi Mikhail
    Yes, that sounds excellent.
    What would be even better is if we can get data for a number of channels (say 101,102,103,104,105,106 of HelloWorld project).
    Kind regards
    Matt
    in reply to: Custom Page #14216
    Matt3
    Hi Mikhail
    Has there been any updates to “custom pages” for V6?
    Kind regards
    Matt
    in reply to: Custom Page #13264
    Matt3
    Hi Mikhail
    Just wondering if there’s been any update on custom pages?
    Also, do you think it’s practical to develop the custom pages in Blazor server-side?
    Matt
    in reply to: Custom Page #12515
    Matt3
    Hi Mikhail
    Aha!!!
    It makes sense now. I’ve started learning razor pages.
    Is it possible to have a few example pages showing how to add a custom page (an example sowing how to get 5 or more channel values would be perfect).
    Matt
    in reply to: Custom Page #12507
    Matt3
    Hi Mikhail
    Thank you for your feedback.
    By moving the custom folder under wwwroot, I can show htm pages.
    Path
    ../../custom/Page1.htm
    Arguments
    View Type
    WebPageView
    Title
    \Page1
    However, when I copy default.aspx page, it is not shown? Are aspx pages not supported?
    Kind regards
    Matt
    in reply to: Custom Page #12495
    Matt3
    Hi Mikhail
    We are using version 5.8.4 with 24 custom pages, in a production environment.
    We tried to port some of our pages to version 6.1.1 but failed, so we tried a very basic html page but failed there too. I can see the menu item “TEST” in the left hand menu but when I hover the mouse pointer over it, it changes to a “no entry” icon (red circle) so we cannot click the link.
    We are using the Hello World sample project and adding the custom page to item 3 in the list. I’ve been in to the browser view source option. I’ve added the source code below…
    1 – In version 6, if I have a file named Test.html, where should I save it (where is the custom folder located)?
    2 – and what path structure should I use when I enter the path, via ScadaAdmin, in the “view” section.
    Matt
    <div class='node-parts'><div class='indent'></div><div class='expander left empty'></div><div class='icon'></div><div class='text'>Simulator</div></div>
    <div class='node-parts'><div class='indent'></div><div class='expander left empty'></div><div class='icon'></div><div class='text'>TEST</div></div>
    • This reply was modified 3 years, 7 months ago by Mikhail.
    in reply to: Custom Page #12206
    Matt3
    Hi Mikhail
    I’m starting to use v6 for live projects.
    I need to add a custom page showing 5 tag values. I modified the code in v5 to read channel data.
    Can you please provide script showing the best way to continuously read the values form from 5 channels and to show the value on the page.
    Thank you
    Matt
    in reply to: Rapidscada.net/stats #11776
    Matt3
    Thank you Mikhail. That worked perfectly.
    in reply to: JavaScript API example custom page #10269
    Matt3
    Hi Mikhil
    Is there an equivalent function of getCurCnlDataExt() in version 6?
    Kind regards
    Matt
    in reply to: SQL Export #10251
    Matt3
    Dear Mikhail
    A 2nd export target fixed the issue. Thank you.
    Kind regards
    Matt
    in reply to: Rapid SCADA 6 Beta #10111
    Matt3
    Hi Mikhail
    I’ve been trying beta 6 and so far so good.
    However, I found a small issue with changing the SCH file path.
    In ScadaAdmin.exe, Tools/Options/File Association/, I can not change the current file path. It is set to “C:\RapidSCADA_Beat_6\Windows\SCADA\ScadaSchemeEditor\ScadaSchemeEditor.exe”.
    Matt
    in reply to: Rapid SCADA 6 Beta #10077
    Matt3
    Hi Mikhail
    Thanks for releasing the beta Version 6. It’s looking great.
    With version 5, we added a lot of pages to the “C:\SCADA\ScadaWeb\custom” folder.
    We used aspx webforms.
    In the release doc for version 6, you mention for the “Webstation” that the “app has been completely redesigned using Razor Pages technology”.
    What technology do you suggest we use to create custom pages in version 6?
    Kind regards
    Matt
    in reply to: 2 or more instances of Rapid SCADA on the same server #9161
    Matt3
    Hi Mikhail
    I’ve been working on this issue today and I have some feedback for you.
    I removed Rapid Scada from the server.
    I then used your install file to install a new version (5.8.3).
    I changed the install folder to SCADA2
    I changed the web link from Scada to Scada2
    Once installed, I tested and it worked.
    I then used the sc.exe program to remove the 3 scada services
    sc delete ScadaServerService
    sc delete ScadaCommService
    sc delete ScadaAgentService
    I then installed the 3 services again but this time with an extension of 2
    sc create ScadaServerService2 binPath= “C:\SCADA2\ScadaServer\ScadaServerSvc.exe –service” DisplayName= “ScadaServerService2”
    sc create ScadaCommService2 binPath= “C:\SCADA2\ScadaComm\ScadaCommSvc.exe –service” DisplayName= “ScadaCommService2”
    sc create ScadaAgentService2 binPath= “C:\Customer1\ScadaAgent\ScadaAgentSvc.exe –service” DisplayName= “ScadaAgentService2″
    In the svc_config.xml, in each service folder, I added the following…
    <ServiceConfig>
    <ServiceName>ScadaServerService2</ServiceName>
    <Description></Description>
    </ServiceConfig>
    <ServiceConfig>
    <ServiceName>ScadaCommService2</ServiceName>
    </ServiceConfig>
    <?xml version=”1.0″ encoding=”utf-8”?>
    <ServiceConfig>
    <ServiceName>ScadaAgentService2</ServiceName>
    </ServiceConfig>
    I started each service from the service control panel. They started.
    I managed to login via localhost/scada2
    Next, I run ScadaAdmin.exe
    I loaded the HelloWorld project
    I click the Upload Configuration button
    In the profile section, I updated the Web station URL to http://localhost/scada2
    In Server / Common Parameters, I update the folders to point to Scada2… C:\SCADA2\BaseDAT\ … etc..
    I click the Upload Configuration button and then click the Upload button
    I get the error…
    Error uploading configuration.
    Unable to login – invalid username or password.
    Also,
    when I select Deploy / Deployment Profile and click the Test button, I get the same error message “Unable to login – invalid username or password.”
    when I select Deploy / Instance Status, for status server and communicator I get…
    “Unable to login – Error validating user” and “Unable to create session” for both.
    Any ideas?
    Thanks for all you support Mikhail
    Kind regards
    Matt
