January 28, 2026 at 7:41 am in reply to: How to display selected command text in a Dynamic Text element #17607
tom040264
ParticipantI solved it with one Button, new ENUM Format and dropdown menue.
Regards
T.January 27, 2026 at 10:31 pm in reply to: How to display selected command text in a Dynamic Text element #17603tom040264
ParticipantHi guys, it’s an older topic, which I want to use for my “problem”. 😉
I have a Modbus device, and want to put a value 0, 1, 2, or 3 into a holding register. An input/output channel exists (e.g. 111).
It should be done by use of 4 Buttons. Each of them sends by click one Value to the channel without any confirmation.
Please advise. Thank you in advance.
Regards
T.tom040264
ParticipantI didn’t copy the folder Chart pro into the Folder
\opt\scada\ScadaWeb\wwwroot\plugins (at raspberry). Now it works.
Thenk you guys!
tom040264
ParticipantHi guys,
I isntalled ChartPro, and got a tryal key. This the log after I uploaded the configuration.
2025-12-19 14:09:40 [linux-server][root][ACT] Webstation 6.2.2.0 started
2025-12-19 14:09:40 [linux-server][root][ACT] Storage FileStorage 6.4.0.0 loaded from file /opt/scada/ScadaWeb/FileStorage.dll
2025-12-19 14:09:40 [linux-server][root][ACT] Plugin PlgChart 6.1.0.1 loaded from file /opt/scada/ScadaWeb/PlgChart.dll
2025-12-19 14:09:40 [linux-server][root][ACT] Plugin PlgChartPro 6.1.1.0 loaded from file /opt/scada/ScadaWeb/PlgChartPro.dll
2025-12-19 14:09:40 [linux-server][root][ACT] Plugin PlgMain 6.1.1.1 loaded from file /opt/scada/ScadaWeb/PlgMain.dll
2025-12-19 14:09:40 [linux-server][root][ACT] Plugin PlgScheme 6.1.1.0 loaded from file /opt/scada/ScadaWeb/PlgScheme.dll
2025-12-19 14:09:40 [linux-server][root][ACT] Plugin PlgSchBasicComp 6.1.0.0 loaded from file /opt/scada/ScadaWeb/PlgSchBasicComp.dll
2025-12-19 14:09:40 [linux-server][root][ACT] Plugin PlgStore 6.1.0.1 loaded from file /opt/scada/ScadaWeb/PlgStore.dll
2025-12-19 14:09:40 [linux-server][root][ACT] Plugin PlgWebPage 6.1.1.0 loaded from file /opt/scada/ScadaWeb/PlgWebPage.dll
2025-12-19 14:09:40 [linux-server][root][ERR] Plugin PlgChartPro: Dictionary file not found: /opt/scada/ScadaWeb/lang/PlgChartPro.en-GB.xml
2025-12-19 14:09:40 [linux-server][root][ACT] Check PlgChartPro registration: Registration key is valid. Expiration date is 20/12/2025.
Computer code: =134A30AEEC340231-F8191A39CF5CE7E9-12A367C7CB8A86AE-4624F99D72D3BEA2-36C1B5C1A583257B-9332C3616C4CF5AD-5DF540FF6BC0ADD2-F7224C389E3EC74A-546D1AFB62238659-A46CD9573AADDBCE=
Registration key: A5B201D04E35A836-4CEF0864BA77710D-2E1FE3AD8E04BF1A
2025-12-19 14:09:40 [linux-server][root][ACT] Plugin PlgScheme: Retrieve scheme components from the installed plugins
2025-12-19 14:09:40 [linux-server][root][ACT] Plugin PlgScheme: Added components from the PlgSchBasicComp plugin
2025-12-19 14:09:41 [linux-server][root][ACT] Receive the configuration database
2025-12-19 14:09:41 [linux-server][root][ACT] The configuration database has been received successfully
2025-12-19 14:09:41 [linux-server][root][INF] The application is ready for operating——————————————————————————–
I can not see any problems or error messages in this log. But each time I click on one channel I get a popup window with a message “UNDEFINED”.
With normal Chart all channels will be displyed without any troubles.
Any idea?
Thx and br
T.
tom040264
ParticipantThank you. I converted my project from v5 to v6, and now everything works fine.
tom040264
ParticipantHello,
I tried this one: https://forum.rapidscada.org/?topic=convert-historical-data-from-v5-to-v6#post-14299
Correction: not ALL links, as I wrote in my last message, but all I have found. 😉
I found the converter and converted my v5-project to the version 6. In the configuration I have 4 communication lines. Two of them work very well, but the other two have some troubles with the communiaction. Under SCADA v5 everything worked perfect.
The difference between the working lines and non working lines is the TransMode:
– working lines TCP
– non working lines RTUI have no idea what for should I look in this forum.
BR
T.tom040264
ParticipantAdditional question: where can I find the conversion tools? All links I have found in this forum are empty.
BR
T.tom040264
ParticipantHello Mikhail,
Thank you for your reply. In the meantime, I found the package (from a very old backup).
BR
T.tom040264
Thanbk you for the answer. I will try it with a project file (*rsproj).
In my project I have 62 input and 9 output channels.
tom040264
ParticipantDear community,
This is an old topic, but I would like to use it for my issue. I have been working with version 5.x since 2018, and now I want to migrate to version 6.x. Everything has been installed, and it is possible to create new projects and open demo projects (HelloWorld).
I want to convert my old project using xxxConv5to6.exe. First, I started ProjConv5to6.exe, tried to convert HelloWorld, and got the following error message:
Convert Rapid SCADA project from v5 to v6
Choose project template language:
1 – English
2 – Russian
0 – Cancel
1
Source project: C:\SCADA\Projects\HelloWorld
Destination project: C:\SCADA\ConvertedToV6\Projects\HelloWorldError: Source project does not exist.
I also tried with some other projects, but always got the same result.
Any ideas?
Best regards,
T.tom040264
ParticipantHi Mikhail,
Nothing has changed. It can happen that everything works 5 times in a row and then suddenly everything gets stuck again. Then I have to start uploading 2-3 times and wait for the timeout until it works again. I haven’t noticed any regularity. Maybe it’s my Raspberry and I should get a new device.
Let’s close this topic. Thanks for the support.
Regards
T.tom040264
ParticipantI did it and will report accordingly.
tom040264
ParticipantCould you try please to open this link:
https://drive.google.com/file/d/19GyHLXJTDAB_COHXx_9WjG5SU20Wv-FY/view?usp=sharing
I am not shure whether it will work.
tom040264
ParticipantI did it but nothing changed.
It doesn’t matter, it’s just a matter of patience. Sometimes it takes a few minutes and sometimes seconds.Thank you Mikhail
tom040264
Participant1. /opt/scada/ScadaServer/svc_restart.sh is not executable.
2. Yes, there is 100% correlation between long waiting for response in Administrator and the “Error controlling service” message.
