123
ParticipantThis is the console that’s having issues.
Error in getLastEventsByView. Failed to fetch
_doCallback @ main-api.js:53
view.js?v=uy3uLs__pqwf_4PNuMHZZbZmSsKFWxFmSbjxll4AxWI:158 09:49:24 Load view 6 from /Main/TableView/6
Error in getCurDataByView. Failed to fetch
view.js?v=uy3uLs__pqwf_4PNuMHZZbZmSsKFWxFmSbjxll4AxWI:158 09:49:29 Load view 5 from /Main/TableView/5
view.js?v=uy3uLs__pqwf_4PNuMHZZbZmSsKFWxFmSbjxll4AxWI:158 09:49:29 Load view 4 from /Main/TableView/4
view.js?v=uy3uLs__pqwf_4PNuMHZZbZmSsKFWxFmSbjxll4AxWI:158 09:49:30 Load view 3 from /Main/TableView/3
VM5404 main-api.js:53 Error in getCurDataByView. Failed to fetch
_doCallback @ VM5404 main-api.js:53
view.js?v=uy3uLs__pqwf_4PNuMHZZbZmSsKFWxFmSbjxll4AxWI:158 09:49:31 Load view 2 from /Scheme/SchemeView/2
VM6390 main-api.js:53 Error in getLastEventsByView. Failed to fetch
_doCallback @ VM6390 main-api.js:53
123
ParticipantThe following is the report content of the Communicator?
But if I go to the /opt/scada directory and first execute scadastop.sh, then execute scadastart.sh to start it normally.ScadaComm.txt
Communicator
Started : 2025/10/20 下午1:44:17
Execution time : 00:03:04
Status : Normal
Version : 6.2.0.1Data Sources (1)
[ScadaServer] Server Data Source : ReadyServer Data Source
Connection : Logged In
Current data queue : 0 of 1000, skipped 0
Historical data queue : 0 of 1000, skipped 0
Event queue : 0 of 1000, skipped 0Communication Lines (2)
[1] RDW6000 : Normal
[2] 定值 : NormalScadaComm.log
2025-10-20 13:44:17 [RD-pc][root][ACT] Communicator 6.2.0.1 started
2025-10-20 13:44:17 [RD-pc][root][ACT] Storage FileStorage 6.2.0.0 loaded from file /opt/scada/ScadaComm/FileStorage.dll
2025-10-20 13:44:17 [RD-pc][root][ACT] 启动逻辑处理
2025-10-20 13:44:17 [RD-pc][root][ACT] Driver DrvCnlBasic 6.1.0.1 loaded from file /opt/scada/ScadaComm/Drv/DrvCnlBasic.Logic.dll
2025-10-20 13:44:17 [RD-pc][root][ACT] Driver DrvDsScadaServer 6.0.1.1 loaded from file /opt/scada/ScadaComm/Drv/DrvDsScadaServer.Logic.dll
2025-10-20 13:44:18 [RD-pc][root][ACT] Driver DrvModbus 6.0.0.4 loaded from file /opt/scada/ScadaComm/Drv/DrvModbus.Logic.dll
2025-10-20 13:44:18 [RD-pc][root][ACT] Data source ScadaServer initialized successfully
2025-10-20 13:44:18 [RD-pc][root][ACT] Data source ScadaServer: Receive the configuration database
2025-10-20 13:44:18 [RD-pc][root][ERR] Data source ScadaServer: Error checking server connection:
Connection refused [::ffff:127.0.0.1]:10000
2025-10-20 13:44:18 [RD-pc][root][ERR] Unable to start communication lines because the configuration database is not received
2025-10-20 13:44:28 [RD-pc][root][ACT] Data source ScadaServer: Receive the configuration database
2025-10-20 13:44:29 [RD-pc][root][ACT] Data source ScadaServer: The configuration database has been received successfully
2025-10-20 13:44:29 [RD-pc][root][ACT] Start communication lines
2025-10-20 13:44:29 [RD-pc][root][ACT] Start reading commands from files
2025-10-20 13:44:29 [RD-pc][root][ACT] Data source ScadaServer: Connection state is Logged In123
ParticipantScadaServer.log
2025-10-20 13:44:17 [RD-pc][root][ACT] Server 6.2.2.0 started 2025-10-20 13:44:17 [RD-pc][root][ACT] Storage FileStorage 6.2.0.0 loaded from file /opt/scada/ScadaServer/FileStorage.dll 2025-10-20 13:44:17 [RD-pc][root][ACT] Start logic processing 2025-10-20 13:44:18 [RD-pc][root][ACT] The configuration database has been read successfully 2025-10-20 13:44:18 [RD-pc][root][INF] Number of active channels for archiving: 697 2025-10-20 13:44:18 [RD-pc][root][INF] Number of active channels for sending commands: 697 2025-10-20 13:44:18 [RD-pc][root][ACT] Compile the source code of scripts and formulas 2025-10-20 13:44:18 [RD-pc][root][ACT] Added the following dependencies: /opt/scada/ScadaServer/ScadaCommon.dll /opt/scada/ScadaServer/ScadaServerEngine.dll /usr/share/dotnet/shared/Microsoft.NETCore.App/8.0.16/netstandard.dll /usr/share/dotnet/shared/Microsoft.NETCore.App/8.0.16/System.ComponentModel.Primitives.dll /usr/share/dotnet/shared/Microsoft.NETCore.App/8.0.16/System.Console.dll /usr/share/dotnet/shared/Microsoft.NETCore.App/8.0.16/System.Diagnostics.Process.dll /usr/share/dotnet/shared/Microsoft.NETCore.App/8.0.16/System.Linq.dll /usr/share/dotnet/shared/Microsoft.NETCore.App/8.0.16/System.Private.CoreLib.dll /usr/share/dotnet/shared/Microsoft.NETCore.App/8.0.16/System.Runtime.dll 2025-10-20 13:44:20 [RD-pc][root][ACT] The source code of scripts and formulas has been compiled successfully 2025-10-20 13:44:20 [RD-pc][root][ACT] Module ModArcBasic 6.2.0.0 loaded from file /opt/scada/ScadaServer/Mod/ModArcBasic.Logic.dll 2025-10-20 13:44:20 [RD-pc][root][ACT] Module ModArcPostgreSql 6.2.1.0 loaded from file /opt/scada/ScadaServer/Mod/ModArcPostgreSql.Logic.dll 2025-10-20 13:44:20 [RD-pc][root][ACT] Archive Cur initialized successfully 2025-10-20 13:44:20 [RD-pc][root][ACT] Archive Min initialized successfully 2025-10-20 13:44:20 [RD-pc][root][ACT] Archive Hour initialized successfully 2025-10-20 13:44:20 [RD-pc][root][ACT] Archive Events initialized successfully 2025-10-20 13:44:20 [RD-pc][root][ACT] Start listener on port 10000 2025-10-20 13:44:20 [RD-pc][root][INF] Archive in DAT format: /opt/scada/Archive 2025-10-20 13:44:20 [RD-pc][root][INF] Archive copy in DAT format: /opt/scada/ArchiveCopy 2025-10-20 13:44:21 [RD-pc][root][ACT] Delete outdated data from the Min archive older than 2024/10/20 2025-10-20 13:44:21 [RD-pc][root][ACT] Delete outdated data from the Hour archive older than 2024/10/20 2025-10-20 13:44:21 [RD-pc][root][ACT] Delete outdated data from the Events archive older than 2024/10/20 2025-10-20 13:44:28 [RD-pc][root][ACT] Session with ID -8567776689079243990 created 2025-10-20 13:44:28 [RD-pc][root][ACT] Client 127.0.0.1 connected 2025-10-20 13:44:28 [RD-pc][root][ACT] Session with ID -7755861321725536353 created 2025-10-20 13:44:28 [RD-pc][root][ACT] Client 127.0.0.1 connected 2025-10-20 13:44:29 [RD-pc][root][ACT] User ScadaComm is successfully authenticated 2025-10-20 13:44:29 [RD-pc][root][ACT] Session with ID -9120833948422862970 created 2025-10-20 13:44:29 [RD-pc][root][ACT] Client 127.0.0.1 connected 2025-10-20 13:44:29 [RD-pc][root][ACT] User ScadaComm is successfully authenticated 2025-10-20 13:44:30 [RD-pc][root][ACT] Client 127.0.0.1 disconnected 2025-10-20 13:45:09 [RD-pc][root][ACT] Session with ID -6124496869083433959 created 2025-10-20 13:45:09 [RD-pc][root][ACT] Client 127.0.0.1 connected-
This reply was modified 1 year, 1 month ago by
123
ParticipantCan following the instructions at the following URL solve the problem?
https://rapidscada.net/doc/content/latest/en/installation-and-run/software-installation.htmlWill the following settings not be applied after performing the above configuration?
General – Start Mode: AlwaysRunning
Process Model – Idle Time-out: 0
Recycling – Regular Time Interval: 0 -
