oley
thank you.
I put those files as described into c:\Program Files\SCADA\ScadaWeb\custom\
mypage.css
MyPage.html
mypage.jsIn web browser I see in the tree view left:
custom
TestAnd the view says Unable to redirect because URL is empty
oley
Finally, there will be about 20-30 objects in the system.
The administrator can see/control all of them and select them from the map.
These objects are assigned to users/owners who should only see their own objects — this works after defining roles.I would like the user/owner, after logging in, to:
– see the map
– see only their own objects on itEvery user owns 1-4 objects.
oley
how to set it up with custom page?
oley
one more question: is it possible for the table view to show only the current value?
oley
I have some other questions according the state.
In the documentation I read:Icons of the Classic type icons are based on an image file. The file name has a suffix corresponding to the object status: undefined, normal, error, and unbound (the status is not bound to a channel).
Than later:
StatusCnlNum – the number of the input channel that shows the object status. Equals 0 if the channel is not specified. Valid channel data: channel status equal to 0 means that the object status is not defined, channel value equal to 0 means the object is normal, channel value equal to 1 means the object is in an error state;So I have to define a channel to visualize the status?
When the unbound icon is displayed?oley
I have several objects, let’s say PV1, PV2, PV3, PV4, which are shown on the map. The administrator can see all objects, of course.
I assign objects PV1 and PV2 to user U1, and PV3 and PV4 to user U2.
After logging in, users can only see views of their own objects, but they cannot see the map, because it is not assigned to any object, but is a collective view of all objects.
Ideally, user U1 would see the map with their objects PV1 and PV2, etc.oley
of course. Now it works fine. Thanks.
oley
I made a correction: I created a calculated channel based on the status of the database channel. Triggers based on the values of this calculated channel fires correctly.
oley
thank you, it works like a charm, but…
Every upload of the configuration rewrite my PlgMap.xml file.
What to do to prevent this?oley
ParticipantAll right, thank you!
oley
ParticipantThank you but I do not really understand that.
If I will read multiple strings from DB, should they have fixed length?
Is this length in characters?
If I have only one string from another table, do I have to create another “dummy” channel to set the length of the previous one?
@JurasskPark I will take a look at this module.oley
ParticipantThank you.
Yes, the events are sequentially arranged in the buffer.
The new ones are written at the top of the buffer.
I have to read as many, as value of 0x0501 register, which stores the count of the events written to the buffer since last read.oley
ParticipantThank you. To clarify: you mean to define 2 device pollings, first for data and second for this log events. Second one should poll only for command?
oley
ParticipantSince I am familiar with the .net framework and the C# programming language, I would most like to program the handling of these events as a driver.
From such a driver, would I be able to read any ModBus device registers and generate SCADA events based on them?
I understand that I need to create the device logic by creating a class inherited from DeviceLogic, access the data via class inherited from DeviceData and creating events using a class derived from DeviceEvent.
The question is, is there a minimal example of a ModBus device driver available that I could follow?oley
ParticipantNext registers contains events from the previous reading.
0x0006 will be the 0x0000 from the previous reading of 0x0501 because 5 new events have been created in the meantime and have been placed at the top of the list.
Next ones are historical data up to the value of 0x0502 (max 1024).
After restart of the device the list is empty and both 0x0501 and 0x0502 contains 0. After first event created both 0x0501 and 0x0502 contains 1, but if we read 0x0501 or 0x0502 and no event occurred 0x0501 is 0 and 0x0502 is 1. -
