Hi Mikhail,
I am performing the same task with another OPC DA server running on a different machine.
DCOM configuration has already been completed.
Using the “MatrikonOPC Explorer” OPC DA client, I am able to successfully connect to the remote OPC DA server. However, when attempting to access the server using Rapid SCADA, I encounter an error: “CoCreateInstanceEx denies access.”
Both machines have installed the following components:
OPC Core Components Redistributable (x64) 3.00.108
OPC Core Components Redistributable (x86) 3.00.108
Could you please advise on how to resolve this issue?
Thank you very much for your help in advance. Wishing you a great day!
Best regards,
Jiujing Xu
