buraksimsek
  • in reply to: schemeeditor doesn’t launch at all – windows11 #16282
    buraksimsek
    I have been trying different solutions to figure out why WCF fails. USed also ChatGPT 🙂 Focused on firewall settings and other rights management solutions… All failed. Then I gave up and used Hyper-V to install rapid scada. Everything worked there. However, all of a sudden I lost connection of the virtual machine. And while I was trying to recover the network settings of the virtual machine, I accidentally solved the above issue…
    I did a factory reset for all network adapters. Then tried rapid scada schemeditor without virtual machine and it works…. God knows what kind of a configuration was there avoiding the connection..
    Thanks for your help!
    in reply to: schemeeditor doesn’t launch at all – windows11 #16266
    buraksimsek
    Hi Mikhail,
    indeed windows event viewer shows errors. There are 3 Errors. The log is very long unfortunately. I assume only the first one tells about the real source more. I hope it helps you to help me 😀
    First one is .NET:
    Log Name: Application
    Source: .NET Runtime
    Date: 3/26/2025 10:37:39 PM
    Event ID: 1026
    Task Category: None
    Level: Error
    Keywords: Classic
    User: N/A
    Computer: LAPTOP-H67AIQA5
    Description:
    Application: ScadaSchemeEditor.exe
    Framework Version: v4.0.30319
    Description: The process was terminated due to an unhandled exception.
    Exception Info: System.AccessViolationException
    at System.Net.UnsafeNclNativeMethods.SetFileCompletionNotificationModes(System.Runtime.InteropServices.CriticalHandle, FileCompletionNotificationModes)
    at System.Net.HttpListener.CreateRequestQueueHandle()
    at System.Net.HttpListener.Start()
    at System.ServiceModel.Channels.SharedHttpTransportManager.OnOpen()
    at System.ServiceModel.Channels.TransportManager.Open(System.ServiceModel.Channels.TransportChannelListener)
    at System.ServiceModel.Channels.TransportManagerContainer.Open(System.ServiceModel.Channels.SelectTransportManagersCallback)
    at System.ServiceModel.Channels.TransportChannelListener.OnOpen(System.TimeSpan)
    at System.ServiceModel.Channels.HttpChannelListener`1[[System.__Canon, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]].OnOpen(System.TimeSpan)
    at System.ServiceModel.Channels.CommunicationObject.Open(System.TimeSpan)
    at System.ServiceModel.Dispatcher.ChannelDispatcher.OnOpen(System.TimeSpan)
    at System.ServiceModel.ServiceHostBase.OnOpen(System.TimeSpan)
    at Scada.Scheme.Editor.AppData.StartWcfService(System.String ByRef)
    at Scada.Scheme.Editor.AppData.StartEditor()
    at Scada.Scheme.Editor.FrmMain.FrmMain_Load(System.Object, System.EventArgs)
    at System.Windows.Forms.Form.OnLoad(System.EventArgs)
    at System.Windows.Forms.Form.OnCreateControl()
    at System.Windows.Forms.Control.CreateControl(Boolean)
    at System.Windows.Forms.Control.CreateControl()
    at System.Windows.Forms.Control.WmShowWindow(System.Windows.Forms.Message ByRef)
    at System.Windows.Forms.Control.WndProc(System.Windows.Forms.Message ByRef)
    at System.Windows.Forms.Form.WmShowWindow(System.Windows.Forms.Message ByRef)
    at System.Windows.Forms.NativeWindow.Callback(IntPtr, Int32, IntPtr, IntPtr)
    Event Xml:
    <Event xmlns=”http://schemas.microsoft.com/win/2004/08/events/event”&gt;
    <System>
    <Provider Name=”.NET Runtime” />
    <EventID Qualifiers=”0″>1026</EventID>
    <Version>0</Version>
    <Level>2</Level>
    <Task>0</Task>
    <Opcode>0</Opcode>
    <Keywords>0x80000000000000</Keywords>
    <TimeCreated SystemTime=”2025-03-26T14:37:39.1014871Z” />
    <EventRecordID>10718</EventRecordID>
    <Correlation />
    <Execution ProcessID=”34740″ ThreadID=”0″ />
    <Channel>Application</Channel>
    <Computer>LAPTOP-H67AIQA5</Computer>
    <Security />
    </System>
    <EventData>
    <Data>Application: ScadaSchemeEditor.exe
    </Data>
    </EventData>
    </Event>
    Second one is directly from schemeeditor referring to Faulting module name: ASProxy64.dll:
    Source: Application Error
    Event ID: 1000
    Task Category: Application Crashing Events
    Level: Error
    Keywords:
    User: LAPTOP-H67AIQA5\burak
    Description:
    Faulting application name: ScadaSchemeEditor.exe, version: 5.3.1.2, time stamp: 0x6274bbe1
    Faulting module name: ASProxy64.dll, version: 2.3.6.3, time stamp: 0x55dda8ac
    Exception code: 0xc0000005
    Fault offset: 0x000000000000c274
    Faulting process id: 0x87B4
    Faulting application start time: 0x1DB9E5C9EEB8CA9
    Faulting application path: C:\Program Files\SCADA\ScadaSchemeEditor\ScadaSchemeEditor.exe
    Faulting module path: C:\WINDOWS\system32\ASProxy64.dll
    Report Id: 30d1fa3c-1e0d-4091-b2d0-914bfafbd234
    Faulting package full name:
    Faulting package-relative application ID:
    Event Xml:
    <System>
    <Provider Name=”Application Error” Guid=”{a0e9b465-b939-57d7-b27d-95d8e925ff57}” />
    <EventID>1000</EventID>
    <Level>2</Level>
    <Task>100</Task>
    <Opcode>0</Opcode>
    <Keywords>0x8000000000000000</Keywords>
    <TimeCreated SystemTime=”2025-03-26T14:37:39.6332350Z” />
    <EventRecordID>10719</EventRecordID>
    <Correlation />
    <Execution ProcessID=”29420″ ThreadID=”20176″ />
    <Security UserID=”S-1-5-21-914742159-529878284-3034585362-1002″ />
    </System>
    <EventData>
    <Data Name=”AppName”>ScadaSchemeEditor.exe</Data>
    <Data Name=”AppVersion”>5.3.1.2</Data>
    <Data Name=”AppTimeStamp”>6274bbe1</Data>
    <Data Name=”ModuleName”>ASProxy64.dll</Data>
    <Data Name=”ModuleVersion”>2.3.6.3</Data>
    <Data Name=”ModuleTimeStamp”>55dda8ac</Data>
    <Data Name=”ExceptionCode”>c0000005</Data>
    <Data Name=”FaultingOffset”>000000000000c274</Data>
    <Data Name=”ProcessId”>0x87b4</Data>
    <Data Name=”ProcessCreationTime”>0x1db9e5c9eeb8ca9</Data>
    <Data Name=”AppPath”>C:\Program Files\SCADA\ScadaSchemeEditor\ScadaSchemeEditor.exe</Data>
    <Data Name=”ModulePath”>C:\WINDOWS\system32\ASProxy64.dll</Data>
    <Data Name=”IntegratorReportId”>30d1fa3c-1e0d-4091-b2d0-914bfafbd234</Data>
    <Data Name=”PackageFullName”>
    </Data>
    <Data Name=”PackageRelativeAppId”>
    </Data>
    </EventData>
    </Event>
    Third one is again schemeeditor
    Date: 3/26/2025 10:37:45 PM
    Event ID: 1000
    Level: Error
    Keywords:
    Description:
    Exception code: 0xc000041d
    Report Id: 14c99ff2-73ac-404b-938d-2d86527d73b8
    Event Xml:
    <System>
    <Level>2</Level>
    <Task>100</Task>
    <Opcode>0</Opcode>
    <TimeCreated SystemTime=”2025-03-26T14:37:45.6459047Z” />
    <EventRecordID>10721</EventRecordID>
    <Correlation />
    <Execution ProcessID=”16280″ ThreadID=”29172″ />
    </System>
    <EventData>
    <Data Name=”ExceptionCode”>c000041d</Data>
    <Data Name=”IntegratorReportId”>14c99ff2-73ac-404b-938d-2d86527d73b8</Data>
    </Data>
    </Data>
    </EventData>
    </Event>
    in reply to: schemeeditor doesn’t launch at all – windows11 #16261
    buraksimsek
    I see under the “Instance Status” it says webstation “Status not supported” Can it be relevant?
    in reply to: schemeeditor doesn’t launch at all – windows11 #16260
    buraksimsek
    Thank you Mikhail,
    I checked WCF. HTTP activation as well as TCP are enabled.
    I checked the TCP Port 10001 with TcpView. 10001 is not in use. 10000 and 10002 are used by rapid scada.
    The log of schemeeditor still shows exactly the same content as above, and stops after PlgSchBasicComp.dll. I do not see an entry for WCF.
    I have .Net Framwork 4.8.1. However in the schemeeditor.exe.log 4.7.2 is noted. <startup><supportedRuntime version=”v4.0″ sku=”.NETFramework,Version=v4.7.2″/></startup></configuration>
    I dont know whether it would make a difference, but I changed it manually. Didnt help…
    It really seems like a wrong or missing configuration somewhere…
    Do you have any other suggestions?
