Viewing 15 posts - 1,381 through 1,395 (of 6,389 total)
  • in reply to: Ngix Further configuration is required. #14038
    Do you use Linux?
    Please open the Administrator application, open the HelloWorld project and check the log file of the Webstation application.
    Or just find logs in the file system and check ScadaWeb.log.
    in reply to: security vulnerability of Rapid SCADA #14023
    Note that you can find similar security reports for any well known SCADA software. Since Rapid SCADA is open source, its internal structure has been tested by many professional developers and we respond to their feedback.
    There are many Rapid SCADA instances available on the Internet that work reliably for many years.
    in reply to: security vulnerability of Rapid SCADA #14022
    What you should do to protect the system:
    1. Follow the safety recommendations.
    2. Restrict access to your project. It’s recommended to store project on GIT in private repository. It helps to control any changes made in the project.
    If an attacker changed your project, he could access the server’s filesystem by read and write operations from the scripts. Also he could add hyperlinks to external resources on the schemes.
    3. Restrict access to the production server. It’s obvious.
    Use firewall.
    4. If Rapid SCADA is hosted in the cloud, enable captcha and use Guard Plugin for additional security.
    5. Use strong passwords in production environment. Change all default passwords.
    6. Run Rapid SCADA services with lower privileges instead of system (root) user.
    • This reply was modified 2 years, 8 months ago by Mikhail.
    in reply to: security vulnerability of Rapid SCADA #14021
    We also checked those CISA reports some time ago. The above links does not contain steps to reproduce the issues, therefore I can answer in general.
    In v6 the following security improvements were made:
    1. Encrypt passwords in configuration files.
    2. Store only password hash for user passwords.
    3. Encrypt sensitive information in TCP application protocol.
    4. Brute force protection.
    5. The web app can redirect only to a local page on user login.
    6. Use more secure default installation directory on Windows.
    in reply to: Server is unavailable #14020
    Restart SCADA-Server, then check ScadaServer.log. Copy start messages from the log here.
    in reply to: OPC UA Server #14015
    > Could not connect to server:BadHostUnknown
    This error means that the computer where the OPC server is installed cannot be found by the client.
    in reply to: Communicator error after PC resume #14014
    When a PC starts, the services should start automatically. You can check the startup type of the services in the Services console.
    Make sure that TCP port 10000 is not used by another application rather than SCADA-Server.
    in reply to: Server is unavailable #14013
    The web app does not show its status, therefore it’s written that it is not supported. To fix the issue, check log files of the applications.
    in reply to: Chart data interval setting #14001
    Using the Administrator application try the following:
    1. Add a new custom archive in Configuration Database – Secondary Tables – Archives
    2. Add the corresponding archive in Server – Archives, and configure the archive options.
    3. Configure Chart Pro plugin to display data from your archive.
    If something in the above sequence is not clear, be free to ask.
    in reply to: OPC UA Server #13988
    You should enable incoming TCP connections to the port 62541 in the firewall settings.
    in reply to: OPC UA Server #13986
    Are there any errors in log files?
    Rapid SCADA OPC UA server can be accessed remotely.
    If you need to publish OPC DA data to MQTT, you can try a Communicator data source that uses the DrvDsMqtt driver.
    in reply to: New ScadaAdmin Project in Version 5 #13984
    will you prepare new models for Version 6?
    Please check this answer.
    in reply to: More detailed archive classification #13980
    1. Open Server – Archives, create a new archive and configure its properties.
    2. Open the Archives table and add the created archive to the table.
    3. If you set the Default checkbox, you don’t need any changes in channels.
    If the archive is not default, set the archive mask of the channel.
    in reply to: Any questions about Rapid SCADA and Raspberry Pi #13979
    is it expected to perform the same as on Raspberry Pi 4 Board
    Yes.
    in reply to: Any questions about Rapid SCADA and Raspberry Pi #13978
    Rapid SCADA 6 works on Raspberry Pi 3, 4 and 5.
