Viewing 15 posts - 1,171 through 1,185 (of 6,389 total)
  • in reply to: iframe is blocked #14650
    Since SCADA use port 80 and the embedded iframe use port 8080.
    Yes. It’s called origin. You should check the error details in the browser console and network tools.
    in reply to: HTTP driver #14647
    Also you can send a request according to the instructions and analyze it by Wireshark.
    in reply to: HTTP driver #14646
    Contact the provider’s technical support and ask for an example of content type and body of the POST request. Then use it in the device properties.
    in reply to: Linux #14645
    Check this topic.
    in reply to: html title when embedding webpage #14644
    If an external web page is open in a frame, we don’t have access to its title, because of browser security. Therefore URL is displayed.
    in reply to: HTTP driver #14638
    Try to configure DrvHttpNotif according to the provider requirements.
    CURLOPT_POSTFIELDS probably should be specified on the request body.
    in reply to: HTTP driver #14637
    Can the phone number of the recipient and the content of the message to be sent be changed?
    Yes. When command is send by Automatic Control module, the phone number is taken from the address book, and the text can contain variables.
    in reply to: Log records #14636
    Do you mean alarms and events or log files *.log?
    in reply to: HTTP driver #14630
    How the system should define what user should be selected as a recipient for an alarm?
    in reply to: Turkish language #14629
    What culture name is set in the Administrator application?
    Changing language affects user interface. Logs remain in English.
    in reply to: Payment for server #14628
    Please check the license terms here.
    > This machine code should be generated for the Linux server, correct?
    Yes. Try trial keys before purchase.
    in reply to: E mail #14627
    Likely, mail server’s host and port are specified incorrectly.
    in reply to: new csv file reder driver #14625
    > How is it done on a file like this one for ex. ?
    Open the file in Notepad, add a new line and save. The driver should read new data.
    > What data is read repeatedly for TagA in Demo mode ?
    Data from the CSV file is read cyclically according the timestamps. If DemoPeriod=OneHour, you should fill the file for the entire hour.
    • This reply was modified 2 years, 4 months ago by Mikhail.
    in reply to: new csv file reder driver #14616
    Demo mode always use the same data. Therefore, you need Real time mode. Seconds don’t need to match exactly. Data considered up to date for 1 minute.
    in reply to: SMS #14615
    Try DrvHttpNotif driver. It can send any HTTP request. Search the forum for configuration examples.
    Automatic Control Module is needed to send SMS automatically according to conditions.
